It's been a while...
Just found an original and complete (other than the cash box) Astro Fighter cocktail, not in too bad shape.
Of course, everything was dead. PSU, Monitor, Boards, all dead.
The PSU now works as it should - drys, cracks around the connectors, and a new 7905 regulator.
The boardset I'll deal with once the monitor is OK.
The 100V monitor appears to scan (from the slight noises from the yoke), yet there's no EHT. It's an NEC PWC-636 board and original CRT. The three onboard fuses are OK, the fusible and ceramic resistors check out, it all looks good. Can anyone point me to a manual for this sort of monitor? If not then I'll probably component it and fit the guts of a Microvitec CUB in its place. The PCB and CRT are currently drying in the (temperature controlled of course) oven, and I'll power it up in bits to measure some voltages in a few hours. I just can't work on filthy equipment, plus it would have to be cleaned anyway.
Thank you!
Thank you!
