myPinballs
Awhile ago i had an original Attack UFO pcb here that was unrepairable. During the process of trying to fix it, i redrew the entire board in a new schematic. This has led me to this project or recreating the board and adding some improvements to it. Using the knowledge and some of the same designs from the mr Do board i was able to recreate this:
- Nice small form factor as the original game was based off the 6560 ic used in vic20 computers.
- Jamma edge connector
- Test points
- Voltage LEDs
- Reset LED
- Modern reset system
- Onboard audio amp
- Reduced chip count form original
- 8 rom version options selectable by dip switch
Should be a nice board to run in a jamma cab. The only complexity is the video out system as the 6560 used composite video. Though some recent replacements have more output options. I'd like to use 15khz RGBS if possible!
- Test points
- Voltage LEDs
- Reset LED
- Onboard audio amp
