CPS1 Help: Kick Harness Space/ Clearance, Right Angle Connectors/ Adapters & JST XH 6 Pin to HST NH 10 Pin Kick Harness
fallinlight
6CR
Hi all,
Hope you are well. I am new to arcade gear and trying to put together a Hyper Fighting kit. I almost quit entirely yesterday after I started to feel very overwhelmed and stressed by it all. But I am persevering and trying to take things in my stride.
So, I have a few questions that I am hoping folks can chime in on, please.
1. CPS1 Case:
I had first planned to use a CPS 1.5 Dash case but was kindly informed the HF boards would not fit - the C board would not have enough clearance for the top of the case shell. My only other option for now are the clear acrylic cases for sale on AliExpress. I know of 2 sellers. Below is one:
Some better photos from a review on the page:
It is difficult communicating with the seller but this particular seller said that they would try to accommodate my needs and build it as I need, which is positive.
Does anyone here have one of these cases? If so, do you know if the kick loom would fit on top of the HF C Board? I don't think there would be enough clearance for the loom based on the photos. And it looks like it would require bending the wires down in an unsafe manner.
2. Right Angle JST NH 10 Pin Connector, or Adapter:
I was thinking I could use a right angle JST NH 10 pin male connector. But I am unsure exactly what this modification would involve. And my soldering isn't good. Could it be done with simple crimping tools only? Failing that, does there exist a pre-built right angle adapter that could simple be attached to the existing male C Board socket? I assume not as I have searched for hours but could not find any.
3. ST XH 6 Pin to HST NH 10 Pin Kick Harness:
The seller of my MiniGun 2.5 Advanced has offered to make me one but does anyone know of anyone selling these readily abialable? The only vendor online that I found is in Australia, and only has 1 left in stock and does not ship to the UK. I think I saw on Arcade Projects someone had made their own, but I don't feel confident in doing that.
Kind thanks,
fallinlight
