Problem MTC9300 20" wierd lines on top - Vertical linerity issue??
7,863CR
I’m no expert on the issue but
Does the middle wave look like the waveform for a bad leaky diode ?
The Diode might read ok out of circuit,
but in circuit Under a higher voltage load than your diode it’s failing.( leaking )
Top vid - component shorting to ground ?
Georgian2
1,867CR
I changed the folowing parts with no difference at all:mad:
D132,128,129,130,131
C142
L105
TH103 (HR7389 the closest spare flyback I have).
5V adjust potentiometer out and pads shorted for maximum (5.5V)
Some other capacitors.
(red and blue are swapped because is an old mtc9000 cable thats why the funny colors))
Second image is without video signal and flyback turned up.
I doubt that this chassis has ever worked, could be some customer return, a production error, f*** knows.
7,863CR
And the tube is fine with other chassis you say ?
It really looked to be in the retrace lines
In the other video ..
ripple from bad caps or power supply ?
Turn brightness right up so retrace lines are very visable just so you can see they are positioned ok in case they have moved ?
Because of the symmetry of those lines it seems to be electro magnetic
Interference causing the wave like shapes .
. Something Out in the deflection circuit ?
Is the hot on it’s way out ? Just slowly collapsing
Georgian2
1,867CR
As one can see in my last post second image, the screen is all they way up. the retrace lines are not in place, somehow all of them are dim and on the upper side. Lifting R38 on the neck board (disable the G1) brings all the retrace lines in place and with the right distace between them.
Ace`
PlanB contributor #1
40 (100%)
3,909CR
Haven't been following but doesn't weird stuff like this usually turn out to be the flyback? or has that already been ruled out
Georgian2
1,867CR
Dose any of you have this chassis? One choke CH102 there is 1 pin not soldered to anything. I can't tell from the schematic if it should be or not. Maybe the pad is missing?? So far the most suspicious thing I found.
M K L
1,119CR
Only two of the four pins are used. The other two are just for support/stability. If you post a pic of the other side It will be clear across which pins the coil is soldered.
