My stuff
gridrunner
Ex-lurker!
206CR
Hi Chaps,
thought I'd add my collection of machinery to the list.
In my home setup there is:
  • Williams Popeye pinball
  • Outrun deluxe upright
  • Sega Naomi cab fitted with marine fishing (have a penchant for bizarre game themes)
at the works gamesroom there's:
  • An Area 51 cab, working OK now, but this game reminds me of Exploding Eddie from Furturama
  • Galaxian table top (Midway US import) plays well
  • Time Crisis single, just getting a new board set hopefully today
  • Midway Cruisin World - Lovely screen in this, plays well, cabinet looks like it's spent the day in Benghazi
  • Jamma cab, soon to be home to Bubble Bobble
Stu's Area 51 cab:
G
Guests
Guest
no such thing an outrun upright deluxe i'm afraid, a deluxe is the sitdown affair.
karlcdoe
887CR
Yes, I suppose it is, I was thinking it was the sitdown until I read your post... Mind you they did about four versions in all and I can never remember what they were officially called.
gridrunner
Ex-lurker!
206CR
Some pictures of the 'games room', including Frankescope.... I've edited these pics so as not to make them stupidly big.
This game's only purpose seems to be the generation of double entendres!
gridrunner2011-06-07 14:11:44
gridrunner
Ex-lurker!
206CR
I learned my craft at the Bazfish school of wiring and electrical safety don't you know.
To quote rule number 4 from the little frazzled brown book of electricaljiggerypokery:
'Never solder tomorrow what you can chocolate block today.'
  • Like
Reactions: trm
gridrunner
Ex-lurker!
206CR
Hi all,
A couple of pictorial updates on a couple of the cabs. First up is the Crystal Maze and some before and after picks. This is a quick and dirty restore to make it look presentable. These Barcrest machines are a bugger to work on but here are some tips to pass on:
Nothing in terms of the glasses or control panel is accessible from the outside, you need to unbolt it from inside the back of the cabinet.
Don't be fooled by the glasses and their surrounds, they don't slide out like pinball back glasses. The best thing to do is remove the glasses in their frames by unscrewing them from the inside of the cabinet. The two glasses and the control panel are hinged, and it's easy to unbolt these small hinges and lift out the glasses in sections. This is the only way to access the control panel.
The trackball is a Wico unit. You can buy rebuild kits online. Mine was gummed up and didn't move at all. I cleaned the rust off the steel rollers with a scotch pad and lubricated the bearings. The shell and ball went through the dish washer. It moves freely now.
The MPU4 CPU needed a new battery and a small acid damage repair. The monitor was a crap job. It needed a new flyback (my last one for a K7000) and a cap kit.
I recapped the MPU4 PSU for good measure. The 12V rail is a little high but it's worked long enough at 15V so I'll leave it alone for now.
The dome is amusing. I put in new foil strips but I'm suffering the same problem the game show had in that they stick to either the floor or sides of the dome!
The game plays fine but has no coin mech for now.
If anyone needs manuals, let me know.
On to Silent Scope. This is Andyman's Frankenscope. The harness has had a haircut to remove a couple of feet of spare wiring and the dreaded molex connectors that joint the original harness. This has conclusively cured the jumping scope problem. The machine is running a Silent Scope 1 board set picked up from ebay and a chap who has de-suicided it.
Great fun.
Oh and Purity's jamma cab now finally has a VGA gamebox monitor and a multiway PCB in it.
