New cabinet / kit
MaNiX
28CR
Hey guys,
Fairly new here so my apologies if this is a frowned upon question. I am looking to build a mame cabinet with my daughter as a little project for fun. To save time I was hoping to buy a flat pack/ready cut one instead of butchering a classic cabinet. Does anyone have experience in this area and have any recommendations? I have found a few just doing a google search but I’m not sure about quality and so on.
I am also purchasing a couple of classic cabinets from a forum member here to start my collection proper, this is very much a fun side project:)
Thanks in advice guys.
Venom
726CR
Hello and welcome.
Although there is some snobbery about mame vs orginal I have both and they can sit side by side :)
Depends on your budget , but you could buy say an arcade 1 up and spend the time and money replacing the buttons and building your own PC or raspberry pi solution for it.
Whenever I look at flat packs the pespsex and mounting of monitor and glue and triim just puts me right of it !
If you use a Dell SFF or something like that the only pain is a lot of them only accept a 1 slot card. I used to have a 1030 in mine but just replaced it and that is sitting in a drawer doing sod all. if you decide on cabinet and in future need a build just give me a shout. I personally would go for coinops collections. Enjoy the googling !
Venom
726CR
Loads of alternatives but I dud this in one cabinet
And I also have a sff behind my Tv :)
MaNiX
28CR
Hello and welcome.
Thanks for your feedback pal that’s great. I know that some of the model 2 and model 3 emulators use. a GPU for upscaling and stuff; but it’s my understanding that mane relies upon just CPU and memory, is that right? If you have a spare 1030 I could for certain use it with an SFF pc. I’m also looking at the coin ops stuff you shared, that will save a whole pile of work thanks mate!
Venom
726CR
Once school holidays settle down will give you a shout and can literally send you my setup should be a copy and paste and you can send the drive back. My 1030 was this one
Gigabyte GeForce GT 1030 Silent Low Profile 2G, Black with the ddr5.​
Its had very little use was only really replaces as woud not run mario kart with Teknparrot that well.
MaNiX
28CR
Mate that would be wonderful thanks so much:) yes that card isn’t the most powerful but it’s great for lots of the older stuff I think, and also small form factor:). I would probably look at a dedicated setup for telnoparrot anyway with a more powerful card. I could definitely make use of that pal:)
penrhos
747CR
I picked up a dead Arcade-1up Streetfighter cab for £75. Swapped the screen for a Dell lcd i had lying around. Fitted a cheap jamma loom and psu into it and its currently running one of those Pandora pcbs (i also had lying around).
If i get time and can be bothered I might try a jamma-jvs adapter and put a spare taito-x2 or Naomi inside it.
Grandkids love it as its small and easy to use.
