Problem Phoenix Nova Apparate GmbH Wallgerät - wall mount
b1ffb0ff
30CR
I recently acquired from another UKVAC member the above.
  • Game: Phoenix (original installation)
  • Distributor: Nova Apparate GmbH, Hamburg
  • Country: West Germany
  • Date: approximately 1980–1982
  • Cabinet type: Wallgerät" purpose-built, compact wall-secured commercial cabinet
It did not come with a wall mount bracket so i got one made for £120.00 out of 3mm steel, they also painted it. I am now looking at setting up a credit method. And the speaker just ain't loud enough for my old ears.
Coining up
I can see the mirco switches in the coin shoot. I can piggy back off them. Not checked but assume it is either NC or NO. I was thinking of using a simple IR circuit to set up a small TX and RX in the mouth of the coin slot, so that when you put your thumb over the slot, IR reflects back and triggers a NC / NO pulse. I would liek top pulse it so it can coin up x 10 times. So, if i was to create a logic circuit to switch this on and off, any ideas on the interval time to give it time to register please?
Speak up i cant hear you...
Secondly, the pot on top right of PCB is fully clockwise so i assume max volume... So... would like to move the the old speaker and connect that output to a small amp input and put a bigger speaker in. Any recommendations here please?
John
WhatsApp Image 2026-08-12 at 11.53.20.jpegWhatsApp Image 2026-08-10 at 21.00.55.jpegWhatsApp Image 2026-08-10 at 21.00.54 (1).jpegWhatsApp Image 2026-08-10 at 21.00.54.jpeg
