Space Duel
retroshaun
51CR
Just picked up this little beauty this morning. Fully working (more or less - see later!), gorgeous monitor with LV2000 installed. Sideart is decent, not perfect - no big scratches, just a little grimy in spots.
When I got it home, everything is working aside from the START button. It lights up, says "PRESS START" but nothing happens. I cleaned and reseated all the contacts on the cone button but thats as far as I got with it as I have a busy day ahead.
Any pointers as to what I should check?
andyman
1,059CR
What a beauty, I want one of those, next vector maybe If I can find one
Swap the switch with the 2 player one to start with.
Andy.
retroshaun
51CR
Yeah thats the problem Space Duel doesnt have 1P / 2P start... just "start" (you select 1 or 2 players from the initial on screen menu, using the button below the start)
DanP
Administrator
2,175CR
Nice score Shaun, I've got one and I love it, altho mine is my vectormame cab now :)
Checkout the pin out, I'd check the pin for oxidation or lack of tension for the START signal on the smaller connector. Also clean the connector pad with an eraser (can't say rubber cos you're in the states). I take it you tried putting it in self test? No bad pokeys reported?
Dan
Pinouts for "Space Duel" (Atari, 1981)
P20: 44-pin edge connector
component side solder side
GND A 1 GND
+5V B 2 +5V
C 3 +22 VDC
D 4 -22 VDC
10.3 VDC E 5
COIN LOCKOUT F 6 COIN CTR R
COIN CTR L H 7 SELECT LED
START LED J 8 ROT L P2
ROT L P1 K 9 SHIELDS P2
SHIELDS P1 L 10 THRUST P1
THRUST P2 M 11 SELECT
SW GND N 12 SW GND
SW GND P 13 SW GND
CABINET R 14 SLAM
AUX COIN S 15
SELF TEST T 16 COIN L
COIN R U 17
V 18
W 19
X 20
+5V Y 21 +SENSE (+5V)
GND Z 22 -SENSE (GND)
P19: 24-pin edge connector
X OUT A 1 X GND
Y OUT B 2 Y GND
C 3 FIRE P1
D 4 FIRE P2
ROT RT P2 E 5 ROT RT P1
F 6 START
RED GND H 7 RED
GREEN GND J 8 GREEN
BLUE GND K 9 BLUE
L 10
AUDIO GND M 11 AUDIO 2
N 12 AUDIO 1
Notes:
- For testing purposes, Black Widow boards can be plugged directly into a
Gravitar harness. If you want to actually play the game, you'll have to
add 4 extra wires at P20:[8/9/K/L] for the extra control panel inputs.
- The "CABINET" pin (P20:R) is potentially interesting. I haven't played
with it, but suspect that if you tied it to GND (or left it open), you
could play the game on a cocktail cabinet.
retroshaun
51CR
OK so what I did was turned it on, did a "select game" (to get both select and start active) and then switched the wiring on both buttons around. So select became start, start became select. After this change over, I can still change the game type selected (ie using the start button) but still cannot start a game.
Hope I have explained that properly!
Basically I have verified both buttons work just fine so its not a button or connection problem. Something specific about the start signal not getting picked up at the board.
Yep - have put it into test, everythign is A-OK aside from the start button not registering!
Will check the pinout next.
retroshaun
51CR
FIXED.
Cleaned connector and reseated a suspicious lookign pin (thanks for the pinout Dan!).
So - Dan - remind me how you set up your vectorMame? Do you have a webpage about it? Did you go with DOS or Linux builds?
