Universal monitor chassis compatibility
tronads
448CR
Have to smile at a couple of the selling points on Ali Express :
  • Age-Inclusive Entertainment:Suitable for players aged over 8, this arcade monitor is a timeless classic for all ages.
  • Ease of Installation:Comes with a complete package, including a coin pusher, making it easy to setup for arcade enthusiasts.
So if you have any bairns under 8, don't let them fit it, and you can use it on Crompton's Penny Falls.
Georgian2
1,790CR
I managed to upgrade the main capacitor, the bridge rectifier and the 140 Ohm resistor. Here can be seen running on an 14" CRT that had an Hantarex MTC9000.
I say the image is perfect, geometry too. This chassis is plug-and-play but if you want it to last longer there are some improvements to be made. I have it running with the original hantarex step down transformer. It could work well with am US250 power supply. This chassis does not have an circuit for degausing. you'll have to use an degausing wand or reproduce the hantarex simple degausing circuit.
