Problem Virtua Striker 2 arcade machine
owen2471
61 (100%)
919CR
Hello
I have the above arcade machine. Am I able to swap out the Virtua Striker board and use Jamma boards in the cab ?
I haven’t a clue with arcade machines.
Thank you
Sbdesign
SEGA collector
16 (100%)
1,695CR
Hello
Thank you
Usually these cabinets have a duel res monitor
15khz (aka low res)
24khz (aka medium res)
You need photos of the rear of the monitor and people on here can identify it to give certainty.
Note: SEGA model 2/3 games are 24khz
This game is model 2.
Normally you switch a plug in the rear of the monitor to switch resolution 15 or 24 kHz.
Jamma games are usually 15khz.
You won’t have cables to plug in a jamma board .
However it is not hard to get a harness and wire it in without any or much molestation.
Sbdesign
SEGA collector
16 (100%)
1,695CR
In essence you need loom £30
I would get a jamma psu £20-£40
the loom
Wires to your buttons
wires to psu
wires to the monitor
change plug to 15KHz and your ready
However to make something interchangeable, is where the workload is much more, and more technical, and a lot more playing around
you could also put a pc in, and splice all the cables up.
what jamma pcbs do you want?
69er
1,707CR
You will also need to wire the loom to speaker(s) and to the coin/credit pcb
If you identify the jamma edge wiring positions on the loom it will be quite straight forward,
Terminals on the coin mech credit board are also usually labelled but easy enough to trace existing wires before you strip everthing out.
owen2471
61 (100%)
919CR
the loom
wires to psu
Thanks for the info.
I’m not sure what Jamma boards I want yet. Just thinking of dipping my toe into the arcade side of things.
I do have a Super Gun also.
owen2471
61 (100%)
919CR
Hello. After digging the Virtua Striker machine out of storage. It switched on and was fine for around 10 mins. Then the first screen came up - see pics and now I don’t get a picture. Is this any easy fix ?
Sbdesign
SEGA collector
16 (100%)
1,695CR
What are you running in it?
Easy? Simple? Cheap?
No idea yet could be main board gone, monitor needs doing, psu not set right or duff, wire disconnected or a loose kettle lead (if you know you know)
owen2471
61 (100%)
919CR
Virtua Striker 2 is running on it. I got the original cab a few years ago and it’s been stuck in a garage.
I’ve just recently used a different kettle lead on it and within a few mins the monitor display went wonky.
The error how ever is a constant neo after 10 minutes or so of play.
Sbdesign
SEGA collector
16 (100%)
1,695CR
I suggest checking if LEDs are lighting on the main board of Virtua striker.
Very important to check voltages of the psu:.
Hopefully it’s low and stopping the model 2 stack from bootong
Sbdesign
SEGA collector
16 (100%)
1,695CR
Only just noticed the text on the black first screen…
You not got a clearer shot?
I’d say we have a power or board issue
And after that based on the pincushion in picture 2, a crt that maybe working to display but is due a service very soon if not now
