ukVac.com Homepage
  New Posts New Posts RSS Feed - Audio probe
Audio probe
 Post Reply Post Reply
Author
Message Reverse Sort Order
KmanSweden View Drop Down
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote KmanSweden Quote  Post ReplyReply Direct Link To This Post Topic: Audio probe
    Posted: 03 Jan 2020 at 2:55pm
Work done. Thanks!
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote KmanSweden Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2019 at 5:30pm
Thanks. I have some ordered now.
Back to Top
philmurr View Drop Down
Senior Members
Senior Members
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote philmurr Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2019 at 5:04pm
Originally posted by KmanSweden KmanSweden wrote:
Cheapest I can get is 1/4 W. Maybe it doesn’t matter for the short time it’s in use?
Neither of the pots are used in a high power part of the circuit so you can get away with very low power ones
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote KmanSweden Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2019 at 12:07pm
Thanks.
Back to Top
jonhughes View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote jonhughes Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2019 at 11:59am
https://www.ebay.co.uk/itm/ALPHA-16mm-PCB-Potentiometer-Linear-Logarithmic-Anti-Log-Pot-Mixer/202730505266?hash=item2f33ae0432:m:m45iM8ugZbSccplWJ1-5q8Q
This is the type I use without any issue
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote KmanSweden Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2019 at 11:34am
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote jonhughes Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2019 at 11:13am
I've got 4.7K standard pots in mine - no idea what wattage it is though.
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote KmanSweden Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2019 at 10:55am
I know I'm bumping an old thread here..
I bought this board years ago from a friend who never did anything with the board..
Picked it up today and found that I dont know what pots to use? 4.7K ohm liner.. What watt? got any good source to share?
Thanks.Embarrassed
Back to Top
jinq-sea View Drop Down
Avatar
3 Years of Supporting ukvac.com!
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote jinq-sea Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2018 at 10:10am
-oops-
Edited by jinq-sea - 04 Aug 2018 at 10:12am
Back to Top
Ace` View Drop Down
Avatar
PlanB contributor #1
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ace` Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2016 at 1:06pm
Mine arrived today, thanks Phil. Hug
Back to Top
Nes4life View Drop Down
Senior Members
Senior Members
Avatar
4 Years of Supporting ukvac.com!
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nes4life Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2016 at 8:24pm
Got mine
NES4Life
Back to Top
Hurray Banana View Drop Down
Moderator Group
Moderator Group
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurray Banana Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2016 at 5:50pm
Mine arrived today, thanks a lot phil
Back to Top
RSwanson View Drop Down
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote RSwanson Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2016 at 5:34pm
That's handy, but you're going to have to be ultra careful with those sensitivity and volume knobs!
Back to Top
Mykill View Drop Down
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mykill Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2016 at 12:33pm
ill try it running on the power from the arcade
Don't touch the red wire
Back to Top
Senior Members
Senior Members
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote philmurr Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2016 at 8:20am
Not sure what you mean in this case by a common ground or running an earth to the speaker.
The probe is powered by the game's power supply so there aren't any grounds to common, and you plug in headphones to hear the amplified sound
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mykill Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2016 at 1:26am
Dose this use a common ground,it tried somthing similar but wasn't sure we're to run earth to the speaker ,I ran mine off a 9v battery and wasn't sure if it was grounded
Back to Top
Senior Members
Senior Members
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote philmurr Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2016 at 5:02pm
Thanks guys - I have some spare PCB's for sale but won't be assembling any more units.  You can make them yourself for less than a tenner!
Back to Top
ianski View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote ianski Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2016 at 3:27pm
Yeah that is cool. As someone who also works on musical instruments I'd find this useful. If you are selling any I want one too :)
My cabs: Track and Field, Mr.Do, Pacmania, Space Ace, Gorf, Jungle King, Astron Belt, Gyruss, OutRun, Frogger, Defender, Return of the Jedi.
Back to Top
Ace` View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ace` Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2016 at 3:16pm
Nice work Phil this looks great, I want one. Smile
Back to Top
Senior Members
Senior Members
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (1) Thanks(1)   Quote philmurr Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2016 at 2:49pm
I've been doing some work lately on some faulty sound boards and old drum machines, and found it quite tricky to work out exactly what part of a circuit was faulty.  You can't really use a logic probe to help, and a 'scope can give difficult to understand readings.
I had a look around for an audio probe (which is used to probe parts of a circuit and hear what's going on), but couldn't find one at a reasonable price, so armed with the LM386 amp datasheet I set out to build my own.  A PCB was designed, plus around £7 of components later and I've a working audio probe.
The probe connects to the power supply of the circuit under test (usually the 0V & +12V of the sound section), you just need to plug in a pair of headphones as it doesn't have a built-in speaker.  The sensitivity and volume are adjustable, and you just touch the probe tip to the part of the circuit you want to "listen to".
It helps answer the "is the power amp or some other part of the sound circuit faulty" predicament as it can prove the working bits of a circuit to narrow down to where a fault actually is.
Photos of the one built unit are below (the probe tip is a nail, until the proper tips I've ordered arrive from China!)
Back to Top
  Share Topic
This page was generated in 0.391 seconds.
