ukVac.com Homepage
  New Posts New Posts RSS Feed - NSM Ultimate NVRAM error
 Post Reply Post Reply
Author
Message
Stevo.s View Drop Down
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stevo.s Quote  Post ReplyReply Direct Link To This Post Topic: NSM Ultimate NVRAM error
    Posted: 07 Oct 2017 at 7:35am
Hi,
I have a problem with an NSM Ultimate Es 6 technology jukebox. An error " Whoops NVRAM IS INVALID" appeared last week . I was advised it would be the yellow battery chip and. Changed this but the issue remains. I also noticed that the laser seems to be pulsing when in this state but not sure if that is relevant ... I would appreciate if anyone has any suggestions as to what might be the issue.
Stevo
Back to Top
Ronnie Dent View Drop Down
Senior Members
Senior Members
Avatar
2 Years of Supporting ukvac.com!
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Dent Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2017 at 8:17am
Should just be the battery, maybe check your soldering and confirm its got voltage.
Ronnie
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stevo.s Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2017 at 9:08am
Thanks for reply Ronnie. The battery isn't soldered, its push fit type. I picked up a replacement but it was used so it might be duff too! I was pretty sure that it was the battery but was curious in case it might be something else. It initially threw up this error but worked again 20 mins or so later but then stopped completely.
I will look on line for a new replacement.
Thanks again
Stevo
Back to Top
Senior Members
Senior Members
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Dent Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2017 at 9:49am
I get them on eBay for about a fiver, there are 2 types on the es6 some have a daughter card that the battery solders too
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stevo.s Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2017 at 6:54pm
Thanks again Ronnie, hopefully get it sorted soon!
Stevo
Back to Top
Senior Members
Senior Members
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Dent Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2017 at 7:52pm
No worries if your board is faulty I might be able to help
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stevo.s Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2017 at 10:07pm
Thanks Ronnie good to know. I will let you know how it goes..
Stevo
Back to Top
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stevo.s Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2017 at 12:09am
Ronnie, I fitted the replacement battery again but left the jukebox on for half an hour and it worked fine! Think it may have been low on charge ? Have since reinitialised discs and is ticking over nicely! Thanks for your help and advice, much appreciated.
Steve
Stevo
Back to Top
Senior Members
Senior Members
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Dent Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2017 at 3:54pm
Great stuff Steve glad it's sorted, see your in Scotland I have a load of parts if you ever need anything
Cheers Ronnie
Back to Top
  Share Topic
This page was generated in 0.219 seconds.
