ukVac.com Homepage
Forum Home Forum Home > Trading Post > For Sale
  New Posts New Posts RSS Feed - Arcade Parts
Arcade Parts
 Post Reply Post Reply Page  12>
Author
Message
davey d View Drop Down
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (2) Thanks(2)   Quote davey d Quote  Post ReplyReply Direct Link To This Post Topic: Arcade Parts
    Posted: 06 Aug 2018 at 2:01pm
Im starting a new thread for the various parts I manufacture.
As time goes on, then I'll add more to the list below:
Prices do not include delivery
Barebones arcade stick housing for use with Sega control panels
Whats included:
1x welded steel enclusure - powdercoated RAL9002(same as sega astro white) or metallic silver
4x rubber feet
1x USB pass through connector
3x buttons
holes drilled in base for IPAC2 + 4x standoff legs
Whats needed to complete the unit?:
1x control panel + buttons + joysticks
1x wiring loom
1x IPAC2 usb encoder
Photos: https://imgur.com/a/4Z1qT6q
Price: £84.00
Barebones Supergun housing for use with Sega control panels
Whats included:
1x welded steel enclusure - powdercoated RAL9002(same as sega astro white) or metallic silver with hinged top
6x rubber feet
3x buttons
2x photo connectors
1x connector + plug for RGB out
1x connector + plug for kick harness out
1x fused mains inlet
2x brackets for mounting MWP-606 PSU
holes drilled in base for Gonbes 8220 + 4x standoff legs
1x Jamma wiring loom
1x Jamma extension loom (for plugging PCB into the supergun)
1x MWP-606 PSU (ideally modified with extended voltage adjuster which i can advise on how to do, or I can supply a modified one for £50.00)
1x Gonbes 8220 Upscaler
Photos: https://imgur.com/a/VCjFu
Photos of complete working unit: https://imgur.com/a/HNZhZiv
Price: £150.00
DP-1167 Locking tang
Used on astro city(maybe others?) with 5380 lock)
3mm Stainless with brushed/ground one side, and plain 2B finish other side.
Price:
£2.50 each for straight.
£3.00 each for bent for coin box with 5380 lock
https://i.imgur.com/pZKYnRT.jpg
Sega fit control panels
Currently have in stock:
1x HOT-2005 (2L12B as used in Naomi/NetCity/New Net City)
0x 2L12B for use with CQN-2004 (astro city 2L12B) (can get more cut if there is demand)
Can get others cut on request for same price:
1.5mm 304 stainless. Requires 2 nuts to be used when fitting joystick like other repro panels
Price: £28.00 each
https://i.imgur.com/gmVr0lj.jpg
https://i.imgur.com/UVMl4Tf.jpg
Marquee topper holder for Japanese Initial D
https://imgur.com/a/x8uxtFw
Price: £70
Edited by davey d - 12 Aug 2019 at 7:04am
Back to Top
muddymusic View Drop Down
Moderator Group
Moderator Group
Avatar
The Repro Guy
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote muddymusic Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2018 at 4:11pm
Nice to see the Japanese pop marquee brackets being made, they aren't easy to get now.
Back to Top
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (1) Thanks(1)   Quote davey d Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2018 at 4:23pm
Sporting one of your marquees too Wink Thumbs Up Cool
Back to Top
robotech View Drop Down
Avatar
3 Years of Supporting ukvac.com!
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote robotech Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2018 at 5:39pm
Nice that someone is reproing controll pannels again
Arnt the initial d and outrun 2 pop brackets meant to slope forwards both of mine do ?
Daytonaaaaaaaaaaaaaaaaaa lets go away
Back to Top
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote davey d Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2018 at 5:54pm
Yes. This one slopes forward (hard to tell in photos), though not as much as an original. When I made them all I had to go on was photos I found online, so they aren't identical to originals dimensionally.
Back to Top
Vamino View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Vamino Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2018 at 8:11pm
Nice job on the bits.
But as Shane pointed out, they are supposed to slope forward to match the angle of the plexi.
When a sloped ID bracket (Or Chinese OR2 bracket) is fitted on top of an OR2 topper it actually points straight up like it does on your ID topper.
So, if your bracket was fitted to an Outrun 2 cab then it would actually slope backwards.
Insert Coin[s]
Back to Top
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote davey d Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2018 at 8:39pm
ok that's no biggie. I've only made the one fitted to my machine so far, so if people want them at a much steeper angle then I can tweak the design to suit. As stated mine is sloped forward, but nowhere near the angle of the front plexiglass, as that looks really steep:
Back to Top
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote davey d Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2018 at 4:32pm
Bump - Still got some bits available Wink
Back to Top
Sbdesign View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sbdesign Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2018 at 3:18pm
any news on the new NEC 2p 6 button steel panels?
Primarily collecting 90's - 2000 Sega
Model 1 / 2 / 3 / Naomi
Back to Top
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote davey d Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2018 at 3:33pm
Do you mean NAC panels?
I've not made any more up since the last batch, as none has put it an order for one. Still got a few HOT2005 panels in stock though
I sent you some dimensions a while ago when we talked about the differences in Astro city overlays, but you didn't get back to me with what you wanted to do?
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sbdesign Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2018 at 3:55pm
Yea, I am useless at times,
Or in reality got too much to do to touch cabs, then when I take a look at cabs, I have took to much on!!!
I'll take  look through the PMS
Back to Top
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote davey d Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2019 at 10:49am
Bump - Still got bits available
Back to Top
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote davey d Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2019 at 12:42pm
Bump - bits still available. Been making up some custom parts too on request. Need something making, then let me know
Back to Top
gaz300372 View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote gaz300372 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2019 at 12:23pm
Payment sent and PM'd shipping details over.
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote gaz300372 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2019 at 4:11pm
Received my enclosure.  very well finished and built like a tank.  Once it's complete I'll add a pic.
Cheers Dave.. Clap (Pics as promised)
Edited by gaz300372 - 05 Apr 2019 at 9:40am
Back to Top
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote davey d Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2019 at 4:18pm
Cheers Dave.. Clap
Excellent - Yes get some pics up please Thumbs Up
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote gaz300372 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2019 at 11:08am
Pics added Dave
Back to Top
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote davey d Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2019 at 12:15pm
Looks good! thanks for the Pics Cool Have you got the Ipac and wiring installed yet?
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote gaz300372 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2019 at 12:22pm
Yeah I do... you want some pics of the wiring too...???
Edited by gaz300372 - 05 Apr 2019 at 12:34pm
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote gaz300372 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2019 at 12:59pm
Changed to a nice one player panel now courtesy of JohnnyChaos
Back to Top
  Share Topic
This page was generated in 0.297 seconds.
