ukVac.com Homepage
Forum Home Forum Home > Trading Post > For Sale
  New Posts New Posts RSS Feed - Flinnster's For Sale Thread
 Post Reply Post Reply Page  12>
Author
Message
 Rating: Topic Rating: 2 Votes, Average 5.00  Topic Search Topic Search  Topic Options Topic Options
Flinnster View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (1) Thanks(1)   Quote Flinnster Quote  Post ReplyReply Direct Link To This Post Topic: Flinnster's For Sale Thread
    Posted: 15 Jun 2019 at 6:40pm
Having a bit of a clear out so I'll try to collate all my sales bits here.
__________________________________________________________________________
Freebies:
Black Naomi Base - FREE!
A jet black Naomi base shell. It has no innards,  just the body of the Naomi base unit.
I was going to get it powder coated for my naomi shell project.
** EDIT: I now have a full set of white coloured front doors and lid for this ** (photos to follow)
More info and photos here
Black Naomi Control Panel support - FREE!
Also jet black metal this is the central control panel support. It was from an 'Ollie King' cabinet, so does not fit a standard joystick + buttons control panel - it does however look similar to the front of some of the driving cabinets, so may well be a shared / universal part.
Yellow Ollie King Plastic Control Panel Cover [ON HOLD]
The yellow plastic cover that sits on top of the control panel metal base above.
I recall it's in good condition with no cracks or breaks, but I will need to dig it out.
(Photos to follow)
Parts:
Used Naomi control panel top (part NOA-1402) - £65 + postage
Solid, but has broken / cracking surface fibre around the coin slot area - someone was clearly a bit heavy handed in a former life.
More photos and info here
Naomi UK/Europe Coin Entry - £5 + postage
Again arcade-used, looks like someone over tightened the rear screw - there is a slight pin-prick hole where the screw point has pushed out the plastic:
4x classic arcade buttons with microswitches (all brand new) - £8 + postage
BAS Control Panel 2L6B - £35 + postage
A pretty nice standard width (54cm) BAS panel with 2 player sticks + 3 buttons per player.
Externally both sticks and all the player buttons are in good condition.
Just the player 1 start button has been stained, possibly by a cigarette stub.
The CPO vinyl is in reasonable condition but sadly has a few little dings and the rear corners are lifting (could be re-glued).
Internally there's some light rust spotting on the lower CP from drinks spills but the hinge is in good condition.
The buttons are all present with decent plungers and all have microswitches except player 1 button2.  Both joysticks feel pretty good, so overall pretty decent.
Dino King / Mushi King / Love & Berry / Sega Mini Cab bits:
Imported Dino King replacement machine screws - £4 for a bag of 10x  including UK postage
I now have both the long & short versions of the cabinet screws from Japan.
(Short ones are used on the back door, mains filter area, and monitor guard - just let me know how many you need)
Replacement Dino King Bezel bolts set - £4 including UK postage
This is a complete set of 4 main bolts for the front monitor bezel, 3 for across the top with the curved rear nuts that fit behind the arched shape.
Original Sega Dino King Security TORX Bolts - £3 including UK postage
I swap these out of my projects so I'm not constantly switching screwdriver types!
So these are up for grabs.
Set of 2x radial cabinet locks & keys (modified for Dino King fitting) - £8 + postage [NOW ON HOLD]
These locks have pre-cut lock tangs to fit the Dino King coin box and main front door.
Should be a drop-in replacement for a lock that is broken or missing.
- Reserved sets for: Vids, DaveO, Popeye64, Sherr03
PCBs & parts/components:
Paradise JAMMA / CHAMMA Adaptor PCB - £2 + postage
This is 'revision 2' of the Paradise JAMMA adaptor PCB. The pin widths have been finely tweaked to
 sit better in your edge connector.
It also features easy solderblob links for pass-through pins, easy separation of the final pins on
the jamma edge should you want to make a full 6 button adaptor / CHAMMA pinout, and has
circular wire holders at each end to tame any spaghetti wiring going over / under the other side
of the pcb.
USB Micro-B Breakout Boards - £2 + postage
These are natty little boards with header pins that I use for supplying power to my Raspberry Pi's on the homebrew JammyPi projects. They make soldering chunkier wires to the micro USB connectors a lot easier!
Puyo Puyo (Sega) Bootleg pcb - £48 + postage
Only selling because I now have the original so this isn't needed any more.
Pretty sure it's standard JAMMA pinout.
SOLD ITEMS:
5x CH/JAMMA Adaptor PCBs - VirtVic
5x CH/JAMMA Adaptor PCBs - Bonehead
5x CH/JAMMA Adaptor PCBs - HurrayBanana
2x CH/JAMMA Adaptor PCBs - Corn
2x CH/JAMMA Adaptor PCBs - AnDyC
Dino King Repro Bezel (all sold, sorry!) - £45 (includes UK postage)
You can see a page with higher resolution photos here.
Supreme 2L8B Neo Geo style CP - SOLD FOR £35 + postage More info and photos here
Wide 2 Player 3 button BAS Control Panel - (sold for £46 + postage) More pictures and info here
Naomi Universal 2L12B Control Panel - (sold for £10 + postage) More info & pictures here
Up / Down Gear Shifter - SOLD £15 + postage - More pictures here
Nintendo Reproduction Coin Door - SOLD £60 + postage - Photos and more info here
Repro Nintendo Cabinet MDF Parts - FREE! [TAKEN]
Pre-cut MDF side panels, base, front panel with speaker cutout, top and partial back for
making up a repro MDF Nintendo wooden cab like Donkey Kong, DK jr, Fix It Felix Jr etc..
(Photos to follow)
Edited by Flinnster - 19 Aug 2019 at 5:53pm
WTD: Outrun DLX cab, Rolling Thunder pcb
Parts WTD: Dino King Door, Coin Box, Coin Chute
Back to Top
digweed View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote digweed Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2019 at 7:19am
PM for naomi control panel Big smile
Wanted: Viewlix, Chewlix or Namco Noir HD cab (oh and some money to buy them please!?)
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flinnster Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2019 at 8:43pm
PM'd backatcha Thumbs Up
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flinnster Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2019 at 3:07am
After a few people requested more, the latest revision (v2) of the JAMMA Adaptor PCBs have arrived!
(So added them in to the first post)
Back to Top
LewisGamer View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote LewisGamer Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2019 at 7:10pm
Can I take the supreme video panel?
:D
Ello!
Back to Top
Brettster View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brettster Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2019 at 9:12pm
do you still have the Naomi Panel? I would like it if you still have it?
Looking for More Space!!
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flinnster Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2019 at 10:31pm
Yep I'll get the extra info you need Lewis on the Supreme panel Wink
Digweed is 1st in line for the Naomi CP, Brettster its yours if he doesn't take it.
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flinnster Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2019 at 11:33pm
Supreme Panel now sold Wink
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote digweed Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2019 at 6:32am
Welcome for Brettster to take it as I do have a few spares but if he loses interest then happy to buy it. Brettster can be first in line
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brettster Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2019 at 1:15pm
got a cab with a butchered panel so with a new overlay this will sort it..
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote digweed Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2019 at 1:21pm
That's cool by me as it would just end up my pile of projects spares Embarrassed
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flinnster Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2019 at 4:51pm
Cool, nice one guys. Over to Brettster then Smile
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flinnster Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2019 at 10:34am
Lowered the price of the remaining control panels and shifter.
Added that the Naomi base now comes with doors and a top lid.
Back to Top
bonehead View Drop Down
Senior Members
Senior Members
Avatar
Call me jamma jim
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote bonehead Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2019 at 11:53am
I will take the Jamma adapter please.
Always looking for a bargain.
Wanted., bezerk, mad planets.
Back to Top
virtvic View Drop Down
Senior Members
Senior Members
Avatar
The Cabaret King
Status: Offline
Feedback: 4.764705882352
Post Options Post Options   Thanks (1) Thanks(1)   Quote virtvic Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2019 at 12:02pm
Dave - you got any of your nice jamma fingerboards left?
EDIT! - Just saw the top of the post.
I'll have 5 please.
Edited by virtvic - 04 Jul 2019 at 12:03pm
THE PENCE IS MIGHTIER THAN THE SWORD!
Check out the podcast
http://tenpencearcade.co.uk
Got cabarets? > CALL ME!
Back to Top
karlcdoe View Drop Down
Senior Members
Senior Members
Avatar
2 Years of Supporting ukvac.com!
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote karlcdoe Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2019 at 12:11pm
I'd like to take the shifter please, if it is still available and you don't mind bringing it along to the smartmeet.
Cheers -K
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flinnster Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2019 at 12:50pm
One shifter for Karl @ smartmeet
5x jammyboards for Vic @ smartmeet
5x jammyboards for Steve @ smartmeet
Smile
Did Eric want some jamma adaptor pcbs too? I guess I'll just bring a load LOL
Edited by Flinnster - 04 Jul 2019 at 1:12pm
Back to Top
Senior Members
Senior Members
Avatar
Call me jamma jim
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote bonehead Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2019 at 1:02pm
I will take 5 if you have them spare?
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flinnster Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2019 at 1:11pm
Yep no worries Thumbs Up
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flinnster Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2019 at 6:50pm
Added some new arcade buttons:
Back to Top
  Share Topic
This page was generated in 0.344 seconds.
