ukVac.com Homepage
  New Posts New Posts RSS Feed - What netdimm is this?
 Post Reply Post Reply
Author
Message
Sbdesign View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sbdesign Quote  Post ReplyReply Direct Link To This Post Topic: What netdimm is this?
    Posted: 08 Apr 2021 at 2:29pm
I just unpacked a netdimm I found in bubblewrap.  Have no idea who it came from now, but its different to al the others.
Here is a picture (not mine)
anyone know the difference? no serial, and cn7/8 on top.
pic not loading so try:
https://www.hklegend.com.hk/images/photos/14/5-b.jpg?10
Its a 840-0008F , 840-0131B-02
Edited by Sbdesign - 08 Apr 2021 at 2:32pm
Do not Sell a Cab to SBDESIGN!
Back to Top
AMS View Drop Down
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMS Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2021 at 3:14pm
I had many in the past and they can be used for net boot etc. They were used on I think the satellite soccer games etc in japan
It’s like a normal dimm unit but lacks the gdrom connector
If you switch the top pcb with a scsi one it’s normal again :-)
Back to Top
jinq-sea View Drop Down
Avatar
3 Years of Supporting ukvac.com!
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote jinq-sea Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2021 at 3:28pm
Yeah that's a pure NetDIMM, as far as I know. Will be fine for netboot!
Back to Top
SIE View Drop Down
Avatar
Status: Offline
Feedback: 0
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIE Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2021 at 3:46pm
How much do they go for? I could do with a netboot setup but they are always big money?
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sbdesign Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2021 at 3:51pm
2 years ago £125
Recently netdimms I've been paying £140 and up ish
Including car hire of £200 to pick up from post office (missed the post) + cod and chips - £370 (£10 fuel)
Back to Top
penrhos View Drop Down
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote penrhos Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2021 at 4:32pm
I've got one of those up for sale bundled with Naomi-1 and RPI net-boot setup as I've converted all my setups to use the Sega CF-solution as I prefer that way of loading the games.
They work exactly the same as a normal Net-Dimm but don't have the circuitry for the disk interface - I flashed mine up to firmware V4.02 using the same process as for the version with both interfaces.
Also if you have a dead dual port net-dimm you can swap the top PCB's over or if you have one where the network port is faulty you can swap to the disk-port version and boot from CF-Reader if you upgrade it to FW 4.02.
They're worth slightly less than the dual-port net-dimm so £100-130.
As you've got one - check the FW version, personally I'd upgrade it to at least V3.17 - although I've had success net-booting with V3.03, don't try and go straight to V4.02 as I bricked one trying to do that.
Edited by penrhos - 08 Apr 2021 at 4:38pm
Back to Top
Avatar
Status: Offline
Feedback: 5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sbdesign Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2021 at 5:16pm
Cheers,
I will do, I'll be asking questions at that point as have a few to update.
Lets hope you see the post when I do ;)
Probably 6 months time knowing me
Back to Top
  Share Topic
This page was generated in 0.203 seconds.
