[SOLD] HAS V3.1 Supergun package |
Post Reply ![]() |
Author | |
AlxUnderBase ![]() Members Profile
Send Private Message
Find Members Posts
Visit Members Homepage
Add to Buddy List
View Feedback
User ![]() Joined: 29 Sep 2019 Location: Constanta Status: Offline Points: 216 Feedback: 5 |
![]() ![]() ![]() ![]() ![]() Posted: 08 Apr 2021 at 3:30pm |
Here is for sale a used HAS Supergun V3.1 The package contain :1 x HAS Supergun (V3.1) - The V3.1 uses the renowned "made in Japan" Hirose brand JAMMA connector with generous gold plating on contacts and general solid feel to it, however these connectors are known for their fragile connector ends which more than often just crack. The ends are cracked on my unit, too, but this doesn't affect the fit and alignment of the JAMMA edge at all 2 x Laser cut 4mm thick Acrylic Glass covers (for top & bottom) , a set of screws and spacers (unasambled) 1 x Power cable high quality 50cm long 16AWG to be used with a PSU + HAS supergun (included with HAS unit) 1 x CPS1 Kick Harness 1 x CPS2 Kick Harness 1 x HD15 Adapter PCB => With this adapter you can connect the HAS with the OSSC using a standard VGA cable (it helps with the Taito F3, which won't work with the OSSC when connected via the Scart). You can also use a VGA->BNC cable to connect it directly to PVM/BVM monitors. The adapter comes with a set of spacers) 1 x 8pin mini DIN to HD15 adapter PCB => With this adapter you can connect the HAS with the OSSC using a standard VGA cable (it helps with the Taito F3, which won't work with the OSSC when connected via the Scart). You can also use a VGA->BNC cable to connect it directly to PVM/BVM monitors. This adapter requires an 8pin mini DIN to 8pin mini DIN cable (pins must connect straight through end to end 1 x DB15 pair of dust caps for controller ports 1 x Retro Acess RGB Scart Cable (6ft option) 1 x Mean Well RT-125A PSU (unopened - unused) 1 x HAS key ring (bonus) I want for this set 200€ + shipping costs (Europe - around 20€ , UK & USA around 25-30€) PS : I also , can sell this set without the Retro-Acces RGB scart cable , Mean-Well PSU , Kick Harnesess with 150€ + shipping costs paypal : friend & family only Pictures : 1 : https://pasteboard.co/JWo2hkn.jpg 2 : https://pasteboard.co/JWo2z6H.jpg 3 : https://pasteboard.co/JWo2JDb.jpg 4 : https://pasteboard.co/JWo2YEC.jpg 5 : https://pasteboard.co/JWo3dmb.jpg Video : https://youtu.be/uhhHMhRchJM Video in action : https://youtu.be/oepSD6V8sY4 Video in action : https://youtu.be/ITKcnhIlx_M Video in action : https://youtu.be/PxrxI6EoV5U Video in action : https://youtu.be/Ni1cUDrqEts Video in action : https://youtu.be/CjcqMxRXjUo Edited by AlxUnderBase - 12 Apr 2021 at 10:22am |
Find Members Posts
Add to Buddy List
View Feedback
Sold for 225€ shipped to an A-P member
Post Reply ![]() |
Tweet
Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
