Id be tempted to check voltages around Q700 , r702, r704, r705 as the collapse is symmetrical.
For a QUICK sneaky check.....To diagnose game board or monitor , you could reduce x and y size one game board a bit, and then swap the x and y wires around (orange and yellow) on the monitor plug.... This will rotate the picture 90'.... if you still get collapse in the same direction on the monitor from the sizes > and < using the other axis, then the monitor needs looking at, if you get the same sort of picture but rotated 90' and you now have vertical collapse, then I'd be looking at the game board.
We want to reduce the x size especially so as not to overdrive the y on the monitor when we swap over.
ColinD2014-12-27 21:38:20
