29e31s remote board potentiometer values
Vamino
Insert coin(s)
2,700CR
Can anyone confirm the values on the remote board please?
I have a couple of missing/damaged pots and the schematic online isn't very clear.
4.7k contrast + brightness?
1k/2k H size/H pos/V size/V pos?
Thanks.
Vamino2018-09-13 19:33:25
Vamino
Insert coin(s)
2,700CR
The remote board got squashed and knocked a couple of pots off and damaged a couple hence the reason the monitor was sold as not working. Man, I sold an untested Sanwa chassis with a nice remote board a while back, ah well.
When I removed the pots they do have the value printed on the rear and there's quite a few different values, 1k, 2k etc. But I don't know what the values of the ones that are missing.
I reflowed the soldering to the connector and ghetto soldered some 5k pots with wires just to test the monitor, thankfully it works and gives a pretty nice picture.
But one of the pots I soldered makes the monitor cut off when the wire is moved so I'll need to try and do it properly and check the cabling. My soldering skills are not as good as yours so I'll remove all the pots and resolder them properly when the pots arrive.
Thanks for the offer mate, but I've already bought a selection of pots off ebay.
If you fancy giving me a mini soldering lesson when you have some free time that would be useful.
Thanks.
Vamino2018-09-13 19:32:20
robotech
823CR
I think i gave all my 29e 32s stuff away
I am no soldering expert but happy to help out mate we can do a bit of soldering next time you come round mine
Vamino
Insert coin(s)
2,700CR
I recieved the pots today and have just soldered the missing ones on.
The monitor works a treat now. The contrast pot must have been dodgy which is why the screen on the lopt was turned right up. Not Nanao quality but it isn't too bad tbh!
I ended up reading through the manual and managed to work out what the schematic says the pots should be, pity the schematic drawing is so dire.
For reference in the schematic it says they are:
5k - Contrast
5K - Brightness
10K - H Size
2K - H Pos
1K - V Size
10K - V Pos
