Have been working hard on a 40 Pin Cpld Module over the past week or two so I can test out my Atari GPC implementation. I need two of these to fix my boards !!
I'm using an Altera 7000S 5V CPLD (cost £10 each) but this should also be able to run 3.3V Xilinx Parts (with optional 3.3v Regulator) which have 5v Tolerant inputs so will also try building a Leta chip too using Jroks code that he kindly released (the code would not build for the Altera chip technology)
The module can be chopped down to 28 / 24 Pins etc.... I had to fit the capacitors / regulator and links on the bottom of the module to make it all fit !!
This uses a 100 Pin IC and different models exist with various numbers of cells available. The IC's have a 0.5mm Pin Spacing so its going to be fun hand soldering these !!!
I've used the spare area which was free to make some cover slips which can be fitted on top for extra protection/stiffness/heatsink/partial rfi shielding and good looks, the pcb's will be black so won't look out of place ;-)
Just sent off the PCB design to be manufactured and have a CPLD chip ready to fit....
Cheers , Col ;-)
ColinD2016-05-07 17:48:56
Cheers , Col ;-)
