ABI and the 8255 Programmable Peripheral Interface
eggwheatis
cheers
65CR
Anyone had issues with the ABI IC testers failing good 8255's? Can anyone test one in their ABI chipmaster or boardmaster and tell me the result? Pulled one...tested bad on one of the I/O pins. Bought 2x off ebay...still fail on the same pin(17). The ones I have are D8255AC-2. Thank.
Ace`
PlanB contributor #1
40 (100%)
4,035CR
I don't know about 8255's but the chipmaster fails good Z80s, I've also had it fail good 6802 or 6808 I can't remember which. I only trust it for TTL and rams but even then I've had it pass TTL that fails in circuit once or twice.
The boardmaster is a bit better and doesn't fail good Z80s but I still wouldn't trust it 100%.
eggwheatis
cheers
65CR
Interesting, note I didn’t desolder this 8255 it was already in a socket having been replaced in the past by a previous tech a year or two ago. The thing is the one I pulled is the same brand and model to the ones I just bought (apart from the batch code is slightly different)…so did the previous tech get a faulty one from the same supplier? If someone could test and 8255 in their Abi all would be revealed ????
