At some point I suspect this will be made into a sticky, but at the moment it's for people to post their own ABI fault codes (and fixes if possible
) and I'll also be documenting the errors/fixes I find whilst working through this pile.
If you do report an error code can you state which version of the firmware you're using please. This can be found on the power-up screen near the bottom and will be 3.10, 3.0 or 2.x. I've found that the error message changes depending on which firmware you have so this information will be useful. Upgrading to v3.10 might also be a good first step to get more info.
You can grab the firmware from here http://www.jammarcade.net/?p=1729
trm2011-08-18 21:59:44
