Before I had the unit, I searched for information online and found a web site that had internal photos. It turned out that mine was slightly different, the monitor and floppy drive are mounted in the top half of the case. This made it tricky to take apart, I had to turn it on it's side and disconnect the cables before lifting the top.
This was taken upside down. The back or the monitor is on the right and the floppy on the left.
The PSU is made by Coutant and looks a bit like a small JAMMA PSU with screw terminals at the front.
I checked the external fuse and the fuse inside the PSU, both were fine so I powered up. Dead, nothing at the outputs, no chirping. The internal fuse was still OK.
The first thing I noticed when opening the PSU was one of the diodes split open on the primary side rectifier. All other semis and capacitors on the primary side look OK with a multimeter, no shorts. Most resistors also look OK on the meter. There was one open circuit 22R 7W ceramic resistor which feeds the side of the bridge with the blown diode.
This is the PSU out of it's case. The position of the diode and resistor are marked.
Now I'm just waiting for my Farnell order to come through.
Does anyone have a photo of the test leads for these older units ?. It has a 50 pin connector on the front instead of two 40 pin.
