AC Line Filter
4,058CR
That's a bit of a random question!!
What do you want the line filter for? You'll need a heavier duty line filter for a 3 phase R360 simulator machine to what you will an Asteroids cabaret. Though while I'm being a little pedantic, a 6A should be enough for most arcade related things it'd be useful to know
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
sorry my question was a bit ambiguous
its for a electrocoin machine running a MTC9000 and a US250
All Single Phase
I did have a peak at bob Roberts site and he suggests a 10A to be on the safe side
which makes me think if im using a supergun and no ISO a 6A just for the SMS alone is fine
would that be about right?silverfox07862014-03-07 01:40:41
4,058CR
A silverline cab, MTC9000 and a US250 will draw nothing like 6A so you should be fine.
Let's be fair, most cabs don't have one at all and I've just removed them when they've failed before, not that I should suggest that you do that! A lot of this stuff was conceived in the early 80's when governments and standards agencies were paranoid about all this guff, and I guess they had reason to be when you had halls stuffed to the brim with row upon row of machine pushing the buildings supplies to their limits.
My mate works for Western Power and he does have a tendency to roll his eyes and go about 1st, 2nd, 3rd harmonics when I start to talk about all the stuff I run (something that means precious little to me, no matter how hard he tries to explain it), but I honestly doubt whether you run an line filter in a lone single cab will make a lot of odds
If there's little price difference and you really want to run one, go for 10A, I can't see it would hurt, but if the 10A is noticeably more then I'd go with 6A or potentially do without entirely?
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
I want to use the line amp as I killed 2 boards and a US300 PSU all in a week
I think it was due to power surge and I didn't have one installed and I just purchased 2 of them for £3.85 each so for that price I think there is no harm in using one.
I went with the 10A just to be safe. and brought some Earth bonding as well to bond the cab.
tbh it just my own peace of mind.
And as you say its all down to regs. for example UK Requires a RFI Filter on a Commando PCB. most people don't even know what that is today and finding one is like finding gold dust in the sea. but it is in fact regulation, but because Arcade Operators are few and far between they don't get those regular inspections as they did back then so using a direct 52pin PCB to jamma adaptor is what every one does where as it should really be 52pin PCB to RFI Filter to 44pin Adaptor to Jamma. Back in the days not having an RFI filter on games that required it like commando would get you in trouble, today how many PAT testers even notice that one is needed.
BTW I have one of those Commando RFI Filters
RaveN
1,325CR
PAT testers test for critical safety issues such as earth problems/leakage, polarity etc.. don't they? They're not concerned about some EMF/RFI surely?
(Correct me if I'm wrong, but this is my understanding of it)
Main line filters are there to protect the cab from transient voltages, and EMI both in and out.
Whilst pcb RFI filters are there simply to protect the surroundings from RFI produced from the game board. It's not a safety issue, but more a radio wave interference issue.
No one uses pcb RFI filters now as there's simply no RFI emitted from pcbs, faulty cpus could potentially produce some but it's negligible. Besides, its only for commercial use, and for home use it's hardly going to start interfering with radio/3g masts. I haven't heard of a Commando RFI filter and I don't think anyone would find it necessary to use one today :/
Although I'm far from an expert on the subject, so feel free to tell me I'm talking out of my bottom.
simonden
20 (100%)
1,042CR
No RaveN, you are pretty much correct, RFI filters are more about interfering with other games in close proximity. Line filters for crappy AC lines coming off petrol generators.
Sarj - more likely you need a surge protector, you can pick up extension cables with surge protectors built in cheaply from maplin/ebay/pc world.
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
RFI radio Frequency Interference has become a big thing in UK just over looked on old arcade PCBs
Mobile Phones need to conform to a strict RFI rating to even be allowed in use in the UK
It down the Cancer paranoia that is present here not interference with other products, unless your in a hospital then RFI would be critical to not interfere with equipment, but then who has ever seen an Arcade in the Hospital
simonden
20 (100%)
1,042CR
That is because of the frequency used. When mobile phones (and PC CPUs) hit microwave frequency, then it became a big thing.
Arcade PCBs do not hit the 700mhz (or is it 800mhz can't remember been a long time) that are within the microwave band.
