I was trying to find what is causing a constant hum in the sound output of my Pac-Man cab, when I noticed the game had stopped working properly. Seems to have gone into watchdog reset mode, or something.
I thought I'd caused the game PCB to go faulty somehow, but when I checked the voltages from the 12 & 7vac transformer, I noticed this oddness...
Measuring from the centre tap lug to the two 7vac out lugs, they both check out fine, but one of the outputs measures low (3-4vac) after going through the fuse block. I measured again at the PCB edge connector, and confirmed the low reading on one of the 7vac pins.
Scratching my head a bit here, as the voltages all measure fine on the transformer lugs.
Any ideas, anybody? Cheers!
