Adding Headphone Adaptor
neogeo13
7CR
Hi Guys,
I have a quick question. I have a Jamma-wired cab and I'm keen to add a headphone jack to it (as we have it in the office and can't keep the volume too high).
Does anyone know an easy way to install this - or any tips on putting in a 3.5mm headphone jack in a Jamma cab?
My first thought was to simply buy a mono headphone adaptor chassis/socket (like the one below) and simply run the wires going to my speaker directly into this. Would that work?
As you can probably tell, I'm pretty new to this ;-)
Thanks in advance for any help!
-Eddie
neogeo132014-09-04 13:08:44
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
where the speakers are PIN 10 and PIN L assuming your using a Mono PCB
where the Speaker wires comes out and goes to the speaker
all you need to do is remove them off the speaker and attach them to a 2 POLE 3.5mm female Jack
being 2 pole you attach PIN10 to the centre and PIN L to the shield
and then place is conveniently on the cab
EDIT:
Just seen your edit
yep that will worksilverfox07862014-09-04 13:11:25
