Got this last year, and it sat in garage all that time, so 2 weeks ago decided to do something about it. If anyone's ever had to move an after burner on their own, load it into a van, and get it in a tiny flat with no movement, and no trolley, I don't recommend it!!
Started with a hoover out, wipe down and access damage etc. Typical operator bodges, In fact this was one of the of the worst! Spend a day removing all the cut connectors and gaffer tape, and now all back to factory spec, with no sign of any repairs. Wiring in handle was shocking! Completely wrong trigger switch and door bell wiring! Again a complete rewire, and a new correct switch, and all back to normal. All fixings are brand new. Original CRT, but newer polo 2 fitted. No PCB, but smarty on order.
Control assembly removed and cleaned. Power base, stripped down cleaned and all back to new. All new fuses, and repaired original power supply, which had a broken solder joint on one of the resistors. Original artwork, which I will leave. This is a UK version.
Things to do:
Missing upper coin door ( If anyone has one please let me know)
Needs all new locks
Awaiting Smarty
Lower left foot needs a repair.
2 replacement decals on lower bezel.
Things to do:
Needs all new locks
Awaiting Smarty
