Afterburner problems
Brettster
1,276CR
Finally got my afterburner monitor sorted so I can spend some time getting the rest of it working
so far I have a really nice CRT test screen the picture is rock solid.
but while there are graphics on screen I get lots of line and corrupted graphics, its not all the time but perhaps you can see what I mean in this short Video
The mem test sometimes passes sometimes shows this error ic 38 looks to have been replaced previously as its in a socket
along with the above
No analogue controls but fire buttons and start button works
no motor functions although it has started up once and shook the stick like crazy and I had to turn it off to stop it
are these power hungry? I've swapped out the PSU and bypassed the spade connector/ splitter thing and the PCB was getting 5.02V to the connectors tried upping this to 5.08V
it also came with a 2nd PCB but this only shows a blue screen with the on-screen joystick moving around but no sprites
can the first PCB be saved or is it back on the hunt for an afterburner PCB!!!
tb2000
3,579CR
Best thing to do first is reseat the ram at IC38, it may be a dodgy socket. If not then you'd need to look at any surrounding LS chips connected to that chip. As far the analog controls go, it looks like they are connected directly to the game board so I should trace from the connector from the control panel back through the circuit. It may be one chip that controls all four directions has gone bad. Not sure on your other probs though!
dj_yt
787CR
The RAM error will either be:
- a bad ram
- a bad logic chip connected to the ram
- a bodged repair job as you mention it's socketed.
IC 38 is Road RAM. The 'road' hardware is used to colour the background of the screen and draw the horizon colours etc. I'm surprised it's causing the sprite flicker, rather than just random background colours. It could be claiming draw priority over the sprites as its failing, resulting in the effect you see.
I would start by tracing the connections of the analog controls back to the filter board and ensure there is continuity. Worst case it's a PCB fault but it could be something much simpler! The SONY CXD1095 chips that are responsible for I/O are off the shelf components, so in theory fixable even in the worst case.
Can you also check whether the controls work on your other PCB if you can get it into test mode?
Mark has stopped fixing X-boards now but given it doesn't look like a custom chip problem you could send it off to get it fixed.
(Edited my post to add some more detail)
dj_yt2017-06-25 23:11:45
Brettster
1,276CR
Cheers guys
I had the other PCB up and running only once and had the machine the wrong way around to try the controls but that PCB has one of the chips blown out that looks like an octocoupler? so im not sure controls would work on that one, but the 2nd PCB wouldn't boot up again a 2nd time
the throttle didn't work on PCB 1 either
PCB #2
5,414CR
When I'd just got my Thunderblade working with replacement monitor, it was all good, it had been playing blind fine before that, I put it back in the corner and switched it on, working great, left it on while moving other cabs about and then the helicopter just started going up and to one side on its own, pots were ok so that must be board fault that just started
Because of that I thought I'll pop in Afterburner PCB, that was playing ok but then noticed the Throttle didn't seem to do anything, working fine on TB and values changed in tests so seems that has input fault also, not had much look with those 2 games
dj_yt
787CR
This era of Sega boards can be a real menace! I'll be moving onto trying to coax some life from my collection of broken boards soon.
I'd get your first PCB repaired professionally. You may be able to donate your fully broken PCB as a donor board also...
Brettster
1,276CR
Mark's had a look at my Afterburner PCB's and they are both unfixable :(
so looking for an afterburner PCB that works if anyone has one for sale?
dj_yt
787CR
That is a sh*tter. I was going to drop you a line and see how you were getting on. What were the problems out of interest?
I have a bunch of X-Boards I'm looking at fixing as you know and am hopefully getting some more (broken) ones at some point for parts.
Unfortunately the recent one I was looking at I believe has a problem with the road custom on the base of the PCB. I need to update my thread with my further progress.
One, I want to convert to a Thunderblade. However, if I get a further one working you will be first in line.
In the meantime, have you considered an approach like this:
http://www.jammaplus.co.uk/forum/forum_posts.asp?TID=80905&title=enduro-racer-dlx
No need to mangle the harness either and when you get a working PCB you can just swap it out. I played on this very cab when I visited Richard a few months back, and honestly, it works great. He is a helpful chap, so can doubt provide some pointers on how to setup a PC or even sell you one.
dj_yt2017-07-19 12:40:17
Brettster
1,276CR
This is Mark's diagnosis on the PCB's
The board that was running with the graphical errors, there are faults with
the Road Custom IC, as well as one of the input Sony chips has failed. This is
also causing the sound not to initialise, as it controls the audio reset.
The second board, I can see an issue on the SD15 line of the slave CPU, but
I can’t track down what is wrong, it looks like it could be one of the math
custom ICs with a bad output causing a conflict of data. Also, that board has
had a voltage spike on one of the inputs, as one of the TL521s has popped it’s
cap. This looks like it’s also caused one of the Sony input chips to fail, as
with the main CPU running, it should at least go into test mode, but it’s not
responding to any input. This voltage spike could have killed a lot of other
things on the board. As I can’t get it into test mode, I can’t check if the
sound PCM custom IC is working, or the other math customs are ok.
I was wondering about a Mame solution but will it also have outputs for the shaker and flashing lights?
dj_yt
787CR
Yes, I believe this is possible. But I am not an expert on MAME stuff at all. Drop 2huwman a line and he will be able to advice.
I leave the shaker disabled as it's really loud and also causes the control panel metalwork to fracture.
