Arcade Machine Debugging
Devil_Mish
87CR
Hey!
I recently bought a machine (of which the conversation can be found here: http://www.ukvac.com/forum/capcom-big-blue-requires-work_topic374203.html) and unfortunately it does seem as lifeless as feared.
I am a complete newbie and have very little idea what I'm actually looking at, I've attached a few pictures below of the screen which has the fault according to the seller and the replacement board provided.
http://imgur.com/a/su03BWn
Any ideas on how I would even begin to debug this beast?
If you need more/better photos, please let me know!
big10p
Coins detected in pocket!
6,093CR
Is it completely dead when switched on? Any sounds or signs of life from the monitor? Have you got a game PCB plugged into it?
Do usual things first: check fuses and all connections. I'd also be giving that Hantarex PSU the gimlet eye of suspicion, as they are known to fail.
Did the seller say the spare monitor chassis is working?
Devil_Mish
87CR
No immediate sounds or signs of life from the monitor unfortunately. I've got a Pandora's box 5S plugged in.
I'm going to spend a lot of time on it this weekend and really understand more about it.
Supposedly that spare monitor chassis is new/working but I am tempted to get someone to test it fully before trying to plug it all up.Devil_Mish2019-12-19 19:19:55
Devil_Mish
87CR
Ok, a bit more information.
The PSU is indeed the Hantarex US150, upon powering on the light on the front doesn't change at all so I assume there is some sort of PSU fault.
Taking it apart I noticed a few bits like burning on the underside, I've attached some pictures.
Also the board provided to supposedly fix the machine is the Hantarex Polo 25 board however I haven't even tried replacing this yet until I can get power to the PSU... Is it worth buying a new PSU?
Hantarex US150 not working https://imgur.com/a/oGWrQ1t
Any help would be much appreciated or if I should look at the cables as well as the PSU.
Thanks in advance!
big10p
6,093CR
Hard to say from the pics if anything is wrong. Dark discoloration is common where high voltage components get hot. Be careful poking around in the PSU (and monitor chassis) as there'll be capacitors in there that hold a high voltage even with it switched off.
So a light comes on the PSU? You need to check the output voltages from it. If you haven't got a multimeter yet, get one - you're going to use it a lot in this hobby. Plenty of vids around showing how to use it.
SUPERSPRINT
1,035CR
You will need a decent multimeter, and the wilingness to do research, watch videos, spend a lot of time finding out about how things work. Even if you had bought it fully working, it is likely to break down at some point.
Basic parts are psu, monitor, pcb.
You need to get your multimeter out and test. No other way to diagnose. You’ll need to find out which part is not working and to do that you need to do your own tests.
Devil_Mish
87CR
Thanks a lot for the advice Big10p and Supersprint! I'll do the research and do some digging around (safetly!)
Just to confirm, the PSU light doesn't come on.
I'll continue to update this post as I find more information, if anything it might help a fellow newbie in a similar situation.
Thanks again
SUPERSPRINT
1,035CR
Fortunately there is a load of videos on the subject of arcade repairs on YouTube.
Johns arcade channel has a load of restoration videos and he explains most things in layman’s terms.
Devil_Mish
87CR
Hi!
A bit of progress, power supply seems fine when tested offline but plugging into the machine it gets nothing, it looks like there is something wrong with either this board to the left of the PSU:
https://imgur.com/a/IO0rnQE
When trying to plug in a cable from that box that is fed directly from the power supply it works, but then if I put the monitor back in with it, it flashes with the green light like it hasn't got enough power... Any suggestions on what that box actually does (is it a voltage amp?) And how I'd go about fixing it?
Thanks!
IanH
277CR
If the psu is dying then it just may not have the power to run anything, first thing i'd do is put a new psu in.
Happy new year
big10p
6,093CR
Probably a faulty PSU. I assume you've checked that fuse in the junction box thing? There seems to be a loads of mains cables plugged into it and I can't think what they're all for! Can you take a pic from further back so we can get a better idea of the wiring.
Eddhorse
528CR
Devil_Mish said:
Hi!
How did you test it offline? Checked the voltages with a multimeter?
Thanks!
I would check the fuse in the picture also
Devil_Mish
87CR
Checked the fuses, checked the switches all seemed OK, I found a post on here from a couple years ago where someone listed the capacitors and suggested replacing them so I'll go from there.
The junction box is fine, just need to get more power out of the PSU now which hopefully that'll resolve.
Thanks for all the help guys
