Arcade to Multisync Projector - Help Needed
Sbdesign
SEGA collector
16 (100%)
1,721CR
Following on from...
a CRT topic here:
http://www.ukvac.com/forum/noob-crt-question_topic384392.html
I asked about MODEL 2 (SEGA) to Multisync Projector.
Ive started THIS thread to prevent derailing that one any further....
@John Bennett gave some insight and hopefully notices this thread...
So far...
*** I did this last night, and it works, but with a Bright picture. Which JB explains why below
JB had said
"(resistors) more to do with protection and signal level.
arcade stuff is TTL levels (5V and something like 1k of impedance), whereas projectors, TVs etc are around 1V ac and 75 ohms, so if you wired it straight, you could be putting in voltages 5x to high to the telly and pulling 20x too much current from the game board. Or something like that - someone with more time than me can do the math(s)."
And regarding wiring..
"That wiring looks ok. You could just go with (the finger-in-air value of) 330 ohm resistors in-line with everything to start with (there's lots of scart-resistor bodge diagrams out there), including the sync."
I don't stock resistors, or have much electronic components...
But after reading many ebay adverts I did buy a box of fuses!
(not even joking)
So I will need to order some, so Just checking exactly what I need if JB or anyone has some links.
(I may have some volume pots, I used on a boot leg SF CE)
I measured the model 2 with a MULTIMETER, using red prong in RGB and Black in GND and it read as 2V approx
Is this the correct way to do it, and means 2v is coming from the RGB on sega Model 2?
Concerned due to the 5v mention above. (but read some are 0-5v, and some 0-2v so does sound correct)
Do I need it to be 0.7V for the projector? (some reading pointed me to this)
Does this mean the 330 ohm resister in line is still correct? (JB did say finger in air)
or am I best of getting some type of mix pack (any recommendations?)
FOUND THIS...
and...
https://www.arcade-projects.com/threads/jamma-to-vga-and-jamma-to-scart.1550/
"Generally with JAMMA to SCART I use 220ohm resistors on R G B and Sync to drop the voltage down. Seems to work fine, and I've used it with tons of JAMMA boards, CPS2, F3, MVS, etc. etc. Some of the JAMMA to JVS converters just use resistors to drop the voltage too."
But in the thread above every known resistor is mentioned.... so Im confused.
Any help with what to order....
5,332CR
For the record, I did also say you really want an op-amp - resistors are a hack
I've looked and VGA isn't quite the same as SCART, in that sync is TTL level, so I can see why folk don't put resistors in there.
5V was a very optimistic RGB maximum - I'd believe it could be half of that.
It's really a potential divider circuit with the 75 ohms inside the TV
So Vout = Vin * 75/(75+R)
So if it was a full blast signal that didn't droop, and 330 ohm resistors, it would be 5 * 75/(75+330) = 0.92V
But yes, it won't be 5V and it'll droop too, especially with resistors on it, but better to have too much resistance than too little. I would expect 220 ohms is fine too.
I'll sort you out with an amplifier one day. I've tried resistors with some games and they still can't cope with the load of 330 ohms, so the picture was incredibly dim as the JAMMA out signal had dropped down to under a volt due to the current draw (I scoped it).
Sbdesign
SEGA collector
16 (100%)
1,721CR
Yes you did - now I need to go google again...
What is a OP-AMP?
Cheers! :)
So if i order some 220 ohm and 330 ohm resisters and see how I get on for now?
For testing sakes.
I may go OSSC on this eventually, as the model 2 resolution doesn't fill the height of the screen 4:3
Ive tried a Gonbes GBS-8200 But the input lag was horrible.
Top skater felt like snow boarding, sega rally 2 felt like snow boarding. Virtua fighter 2 felt like well...snow fighting.
5,332CR
Think of it that the resistors downscale the signal, but the operational amplifier (14-pin IC) acts as a protection buffer, so it steps-in to provide the power for the signal into the TV/monitor, not the game board.
It means you can use much higher value resistors like 1K, which load the arcade board as it was intended, rather than putting lower values on and causing the signal to droop and things to get overloaded.
