Are these the same chip
bones
1,628CR
Hi,help, I've googled these and they appear the same but is a 74hc109 the same as a 74ls109 ? I'm working on a Sega wonder boy(single board) and I pulled a D74HC109C from position 2N and my tester does not recognise the device,it reads a spare 74ls109 fine. Does the initial 'D' at the start of it's number mean it's something completely different than a JK flip flop ?
5,332CR
I wouldn't change types, sorry. If it's HC, or F, stick with that.
The voltage thresholds, delays and current drive capabilities vary from LS series.
The more modern 'HCT' series do seem the best for compatibility with LS and HC (they can cope with the weedy input voltages from LS, can do almost 0 to 5V output range like HC, deliver lots of current and are fast, but I'd still go original if possible.)
bones
1,628CR
Thanks, just noticed that PCB has ls109 screen printed on it when I went to solder the socket in lol. I'll get a couple of hc's anyway. This one had a 4k7 between +5v and pin 11 for some reason. Probed it with the ls109 in it's place and the outputs are flashing now but no difference to the corrupted graphics. There's another one of these 109's and it's outputs and inputs are not changing no matter whether it's in attract mode or in play mode so I guess being a flip flop that's worth investigating where things are coming to it from. Such a pain there being no schematics for this PCB. I've had to map out a lot of the rams because of a previous attempted repair that had destroyed many traces underneath the sockets but you're never quite sure if you've pinned all the destinations.( PS I was told that the edge connector was plugged in upside down when it originally died ugh)
Enough waffle and back to insanity, thanks people.
