Hi everybody
Looking at an asteroids PCB that has some issues, board is watchdogging but also on checking all the voltages i'm not getting what I should have on the 36vAC rail.
I should have approx +/-22v on C86 and C87, however, i've not got that, i've got about 0.8v on C87 and -48v on C86.
My thoughts were the 4 x 1N4001 diodes so i've replaced these, one of the caps (C86) was leaking so that was also replaced and I replaced C87 as well. Both replaced with 470uf/35v caps.
I've verified i've got 36vAC by using the edges of C84 and C85 before they hit the diodes - I have 37vAC in total across those points.
I have everything else hooked up and when I power up I can hear the test mode beep going on and it resetting constantly but its very faint and no vector output because the LM7815/LM7915/LM7805 aren't producing the right voltages.
This is the place I always get a bit tied up in the power supplies as they don't seem to behave how I expect.
I've had the LM78xx/79xx regulators out of circuit to try and stabilise the DC side but the voltage never gets anywhere near 22v at the two capacitors.
I compared to another board which has some graphics issues and the voltages are right on there.
Puzzled....
Puzzled....
