Asteroids brightness issue
forcefulfil
EDOT King
17 (100%)
1,675CR
hi gents
Have a full size asteroids here
Electrohome g05-801.the screen keeps going bright to the point u get retrace lines. It happens occasionally and only momentarily.
I have turned down the brightness and contrast to help make it less visible.but none the less it still occurs.
I know its not the pcb or deflection pcb.
Is this something to do the the HV doubler on the HV pcb?
Any help much appreciated as always
Phil
bonehead
I'll get pix tonight
50 (100%)
1,729CR
My guess is the HV diode. Had to replace one w monitor this week as the picture was too big.
Not sure you can buy them in the uk.
forcefulfil
EDOT King
17 (100%)
1,675CR
The g05-801 doesn't have one.
There in the 802. The doubles are as far as I know obsolete
lix
546CR
For reference, I replaced the bad HV diode in my Asteroids monitor with two microwave diodes connected in series. The diodes are rated at 12Kv, so in series they can handle upto 24Kv and well within the voltage range of the EHT output to the tube.
It's not a straight swap obviously, I just soldered them inline with the EHT wire and wrapped them in several layers of heat shrink tubing. The old diode cap rubber had perished and the coiled springs were gone so I couldn't keep it as originally intended. The microwave diodes are doing a good job so far!
I got a pack of five CL04-12 from ebay for £4, so pretty inexpensive.
forcefulfil
EDOT King
17 (100%)
1,675CR
Cheers for that.im 98% sure this is the problem
forcefulfil
EDOT King
17 (100%)
1,675CR
ColinD said:
Are you sure your pots are nice and clean ? - At 40 years old, I'd expect to see some issues with them being a bit scratchy !
Yes Colin monitor was rebuilt by myself about 2 years ago.
Its deffo on the hv board.but I dont have a spare here to swap it out,and if it used the hv diode I could simply swap it out to eliminate. Its just something that has creeped up slowly.
I even replaced the pot and adjusted the hv.
