Tore-Norway
- Credits
- 1CR
Hi guys, new member here, located in Oslo, Norway. Electronics engineer.
I am restoring an Asteroids Cocktail. It's firing up normally in test mode. However, when I set the test switch to normal game mode, it runs normally for some seconds and then resets repeatedly, not periodically. It's looking like screen flicker. If I set test mode again, all is normal.
I have changed all electrolytic capacitors and adjusted the main PCB voltage to 5V. The supply voltage is not changing when the game runs/resets.
Any tips on why the game behaves like this?
Thanks and cheers from Oslo,
Tore
Tore
