I picked up an untested Asteroids a couple of days ago and gave it a test tonight.
It's a very clean board, with no obvious repairs as far as I can tell. Edge connector has a burnt finger though which will need sorting.
Powering it up all voltages checked out OK, but reset pin 40 of the 6502 was pulsing. So, it doesn't work then.
Entering test mode however gave a promising stable reset line, and vector generator HALT line on pin 9 of chip at A9 was giving a 68Hz square wave, which is what you'd expect a working Asteroids to show.
Next was to hook up a scope as a test monitor.
So it shows a good vector image, though that looks like ROM error text characters at the upper left of the test grid. Difficult to really see until I one day hook up the scope Z axis to give proper image blanking...one day.
So next I unplug the 6502 and plug in my crude tester. Hmmm, doing a ROM checksum shows a faulty ROM. Time for a quick burn of a replacement
That gave better results
So a duff ROM then. Lets take a closer look before binning it.
A-ha!! A bent pin, wonder if I can bend it back without breaking it, like I so usually do
Woo-hooo! A fully working board, with sounds and inputs tested now. Running what look like original ROMs, with no signs of repair. Wow that's pretty good going from my experiences with Asteroids boards!
I'll clean up the ROM legs a bit more with a fibreglass pencil, seems to do a good job of gently removing the black surface corrosion that so many Asteroids PROMs seem to suffer from.
Next up will be to test the Battlezone board I picked up from the same seller in a similar good condition, but that's going to be rather more difficult, as the math/sound board is missing, I only got the main CPU/vector board. Anyone got a Battlezone math board for sale? Working or not. Otherwise I might have to build a math board function into my CPU tester, and that will be difficult.
