Hi guys,
Im trying to put my Asteroids together with the pile of parts I have, anyway the brick I have is from Battlezone and is slightly different and with a different plug. I checked the docs and they look compatible so ive changed the plug so they fit following the wiring diagrams. the game board powers up, the spot killer led flickers once then goes out and it sounds like I have vector chatter from the monitor but the neck doesnt glow and I get no picture, dont know if there is HT or not. The 30v-0-30v is correct at the monitor plug. I checked the 6v AC and when the monitor is connected it is 0, but if I disconnect the monitor it is correct. The fuse(s) does not blow.
I have tried a 2nd 15" monitor I have and get exactly the same syptoms.
Does it mean the brick is bad ?
Thanks in advance for any help
