Asteroids HV Diode
t-m
333CR
I was looking at replacing the HV diode in an asteroids monitor last night and the insulated end caps are crusty, brittle and falling apart.
Anyone got any suggestions how I can repair this?
Monstermug
1,807CR
Quick and dirty way might be to try using high temp silicon sealant, but personally, I would find a similar sized replacement boot or possibly encapsulating the HV diode with RTV silicon after soldering it in place (a bit like the G05-801 voltage doubler).
I'm about to make a few voltage doublers for the G05-801 using RTV silicon, hv diodes and HV caps so if you want to wait I will let you know if it works!
Whatever method you use, it's always a good idea to line it with high temperature grease to prevent the rubber from going brittle.
t-m
333CR
This is how I fixed it in the end - with a piece of silicon tube cut to size, wrapped around and cable tied in place. This works well as it supports the whole diode, if you just put rtv silicon over the ends the connection may twist and break as you reattach the anode cap.
