Asteroids resetting
Nes4life
1,134CR
My Asteroids started watch-dogging so I pulled the PCB.
Removed the high score board and then inspected the board. Didn't see anything obvious.
Reseated all the socketed chips near the 6502 and still no change.
Pulled all the socketed and recognisable 74LS ICs and tested them; found a dead 393 at D1! Tested the other 393 and it passed.
Have ordered a handful more and will let you all know if it fixes it.
philmurr
48 (100%)
2,374CR
The ZIF socket on mine doesn't always make very good contact. Try slightly twisting the chip when in the socket (so it pushes up against the contacts) then run the test again, see if that works.
