After the success of the Battlezone vector PROM (
http://www.ukvac.com/forum/battlezone-vector-generator-prom-replacement_topic356846.html
I thought I'd better try an Asteroids vector PROM next.
This went a lot faster tonight, so below is the JED text file for Asteroids, Asteroids Deluxe and Lunar Lander vector PROM replacement with a GAL22V10, same as described in the link above.
I have only tested it very briefly on a faulty Asteroids PCB, but the test screen grid appeared which gives me pretty good confidence that it is working OK. The board has other faults though so I can't get it out of the test screen.
Device g22v10 Library DLIB-h-40-1
Created Wed Mar 08 21:45:36 2017
Name DVG_PROM
Partno DVG_PROM
Revision 01
Date 08/03/17
Designer Mitchell Gant (credit to Retroclinic)
Company
Assembly None
Location None
*QP24
*QF5892
*G0
*F0
*L01472 00000000000000000000000011111111
*L01504 11111111111111111111111111111111
*L01536 11111111111111111111011110110111
*L01568 11111111111111111111111111110111
*L01600 01111111011111111111111111111111
*L01632 11110111011101110111111111111111
*L01664 11111111111101110111011111111111
*L01696 01111111111111111111111110111111
*L01728 01110111011111111111111111111111
*L01760 11111011111101111111011101111111
*L01792 11111111111101111111111101110111
*L01824 01111111111111111111111101111111
*L01856 11110111111101110111111111111111
*L01888 11111101111111111011011110111111
*L01920 11111111111111110111101110110111
*L01952 11111111011111111111111111111110
*L01984 11111111101110111011101111111111
*L02016 11111111000000000000000000000000
*L02144 00000000000011111111111111111111
*L02176 11111111111111111111111111111111
*L02208 11111111111101111011111111111111
*L02240 11111111111111110111011110111111
*L02272 11111111111111111111111111111011
*L02304 01110111111111111111111111111111
*L02336 11111111101110111011111111111111
*L02368 11111111111111111011111110111111
*L02400 10111111111111111111111110111111
*L02432 11111011111110111111111111111111
*L02464 01111111111111111011111110111111
*L02496 11111111111111101111111111110111
*L02528 11111011111111111111111101111111
*L02560 10111111101110111111111111111111
*L02592 11110111101111111111101110111111
*L02624 11111111111111111011011101111111
*L02656 10111011011111111111111111110000
*L02880 00000000000000000000000011111111
*L02912 11111111111111111111111111111111
*L02944 11111111111111111111101110111011
*L02976 11111111111111111111111111110111
*L03008 10110111111111111111111111111111
*L03040 11111111101111111011101111111111
*L03072 11111111011111111111011110111111
*L03104 11111111111111111111111111110111
*L03136 01111111011110111111111111111111
*L03168 11110111011101111011111111111111
*L03200 11111111111111111011111101111111
*L03232 01111011111111111111111101111111
*L03264 11110111111101111011111111111111
*L03296 11110000000000000000000000000000
*L03648 00001111111111111111111111111111
*L03680 11111111111111111111111111111011
*L03712 01111011111111111111111111111111
*L03744 11111111101110111111011111111111
*L03776 11111111111011111111101111111011
*L03808 11111111111111111111111111111111
*L03840 01111011011110111111111111111111
*L03872 11111111011101111111011110111111
*L03904 11111111111111111011111101111111
*L03936 01111011111111111111111101111111
*L03968 11110111111101111011111111111111
*L04000 11110000000000000000000000000000
*L05792 00000000000000000100000101010100
*L05824 00000100010001010110010001110101
*L05856 11110101000001010010010011110100
*L05888 1101
*CDD1C
*4F1D
Name DVG_PROM
Partno DVG_PROM
Revision 01
Date 08/03/17
Company
Assembly None
Location None
*QP24
*QF5892
*G0
*F0
*L05888 1101
*CDD1C
*4F1D
