Atari AR2-01 Rebuild
nurtuo
326CR
Finished both my Pole Position AR2-01s and they are testing up all good.
I bought a Full Correct Spec Rebuild Kit, from arcadeshop.com in the US.
Including Nichicon Caps, Resistors, Transistors, Regulators and Diodes.
Empty.
Finished.
nurtuo2021-06-02 18:50:45
Equites
Chief Sheesher®
35 (100%)
3,329CR
I've yet to find an AR2 that actually needs the caps to be replaced.
Atari used very high quality caps back then which will outlast the modern caps being used these days.
For that reason I no longer change them.Equites2019-10-21 11:36:19
tb lilley
5 Star
1,686CR
I’m about to do one of mine. For a Battlezone. Transistors and regulators only. But that’s mostly because I’m too idle and tight to do the rest.
Equites
Chief Sheesher®
35 (100%)
3,329CR
nurtuo said:
The kits from the US were only $14.95 per AR2 plus postage.
And were the original Makers quality and Specs.
Did the kit include the 1k pot for the +5vdc? I dont see it.
These should be replaced as old pots tend to drift over time.
nurtuo
326CR
No it did not include those.
Both mine are really nice to adjust at the moment with no drifting,
but I presume you recommend replacing those as well?
Equites
Chief Sheesher®
35 (100%)
3,329CR
I always do, especially those wheel type ones.
forcefulfil
EDOT King
17 (100%)
1,675CR
Hence the original blob of silicone to help keep em still.you can move a cab and the voltage has altered with those types.
I always mod the ar2 aswell especially with a pole position camp fire
nurtuo
326CR
LOL. Sorry Forgot to say I had also done the Sense Mod on them both.
And put new Batteries in the smoke alarm and got a nice CO2 Fire Extinguisher ready.
Come on this is Pole Position. More Dangerous than the Racing Car it was based on!!
nurtuo2019-10-21 15:45:53
forcefulfil
EDOT King
17 (100%)
1,675CR
They are looking good indeed.
I just couldn't resist a spot of banter
Pole position is a game I always heard in every arcade throughout the land as a kid.and have very fond memories of it.
nurtuo
326CR
One of my early favourites as well.
Your Cockpit Pole Position was a real lovely.
I missed it by not much.
I am pushing on well with my upright now.
The PCBs have already been to Marks for there Annual check up.
nurtuo
326CR
Fitted the new 1K pot as advised, thanks guys it adjusts so much better now.
Also fitted some fans on the bottom of the heat sink to keep them cool.
Its been running for over 5 hours today and nice and cool to touch.
nurtuo2021-06-02 18:52:17
patloz
844CR
I gave up using the AR2 to power the PCB in my PP cabs.
I recently had an issue with the screen flashing slightly which I just couldn't figure out as everything tested fine but soon as I fitted a switcher delivering +5v direct to the PCB +5v points its been perfect.
Taking a massive risk saying this BUT since adding the switchers I haven't had any problems that I was suffering with running two PP cabs back to back such as random resets, startup rom errors and minor graphic glitches.
You have made a cracking job rebuilding the AR's though!
patloz2019-11-29 20:28:28
