Atari asteroids ram problem
bonehead
I'll get pix tonight
50 (100%)
1,729CR
Ok picked up an asteroids pcb today and tested it.
In self test it bleeps to say that ram chip m4 is faulty. I have piggy backed a known working chip but it won't go past this error. Tried 3 chips and all the same result.
Could there be another fault on the pcb not allowing it to go past this section? I know that the test mode stops at the first bad chip but don't understand why it won't work with a known chip.
Any direction?
smarty
Ready Player One
1,305CR
I don't think piggybacking RAM is reliable to prove a fault unless you can see changes in graphics (on a raster game) unlike piggybacking some 74 series logic which works well in a lot of cases..
I think you need to change the RAM in the 1st instance if there are no other signs of damage on the board and go from there.
Monstermug
1,807CR
Sometimes asteroids will report a problem with ram if the cpu cannot access it. Maybe check the address lines for floating or stuck i/o's and trace back. Iirc M4 is a vector ram.
Monstermug
1,807CR
The CPU wouldn't be the fault. Most probably a bad ram as the test suggest or can often be the address decoding circuit. If you want I can look at it for you when I stitch back your WG6100
. Still got a few pcbs to give back to you too. Just not found any time to do anything with my day job atm and the lovely distracting weather!
bonehead
50 (100%)
1,729CR
No problem. I also haven't done anything for over a month. Today is the first day I have even been in the games room for over a month due to family things.
Will give you a shout next week.
Nes4life
1,134CR
You've got a few options. Personally I find piggy backing does work with Asteroids but usually I piggy back all the vec RAMs and the other 2 general RAMs. If no joy then it's likely to be the buffers between the ram and the cpu. As you're getting beeps the cpu is fine (and some of the sound circuitry). As suggested you could get the logic probe out and see if there's any stuck address or data lines. You also want to check the ram at m4 is getting the select signal etc.
The fun starts after you get passed this stage and find there's various vector state machine and sound issues!
Also happy to take a look at this for you.Nes4life2017-07-23 14:04:10
