ataridude74
I have an Atari Breakout PCB which has some faults.
1) The score increases rapidly, even in attract mode, cycling 0-999 constantly. Affecting both players.
2) The game credits, starts and serves a ball when the button is pressed but the ball goes straight through the brick wall without registering.
3) The bat is present but doesn't move.
It is not the pot on the paddle, it is flaky but tested 0-4KOhms.
4) There is a buzzing through the speakers.
I assume this is old caps in the audio section.
I have swapped out the 4016 RAM chip, made no difference (assuming either works). They run very hot.
The PCB is getting a steady 5V. The regulator and resistor run hot, but this is normal apparently. The edge connector had burnt pins, but I have bypassed these through wires straight to the PCB (via the RF filter board).
I have the schematic so can narrow it down to 1/3 of the total chips, but before I start shotgunning everything does somebody have some suggestions to narrow it down?
