Atari couplers a035220
hendrix77
5CR
Hi I was wondering if anybody repairs this sort of thing. There from a super sprint steering wheel set up. I can’t find any replacement parts any where. In the us they sell pole position replacements but not these. Thanx in advance
1bradders
133CR
What's the symptom, no steering? If you have a multimeter I'd check the continuity of the traces/between pins. Also use a dry cotton bud and clean inside the optocoupler. Have you tried swapping the optocoupler from another wheel to rule out its not something else?
hendrix77
5CR
hendrix77
5CR
Hi thank for the response yes no movement on the steering. I checked all pins etc seam ok washed pcb down and dried etc. no reason too not work unless it’s the sensors but there’s two on them. I’ll try the ear bud trick see if that works
1bradders
133CR
Also checkout this thread that might help - https://forums.arcade-museum.com/threads/fix-atari-a035220-02-steering-board.322702/
If you plug in the board can you see the two optocoupler leds lit? Apparently they are wired in series so if one sensor is out neither will work.
"One problem I've found for a "No steering" symptom as if the board is not connected is this:
Look closely at the steering/trackball board. Notice that BOTH of the LED (light emitter) sections are wired in SERIES with each other. That means if one of the LEDs inside the opto coupler unit dies, it kills power to the other LED. Hence the unit appears dead. The phototransistors inside the coupler unit then have no light at all getting to either of the phototransistors. So no light = no movement."
hendrix77
5CR
Ok I can’t see any lights on them at all to me it just looks like a bit of black plastic. But i will take another look later when I have time. All the pins have continuity so I’m guessing they all work ? Maybe just dirty ?
1bradders
133CR
Try use your phone camera to check the LEDs are working correctly as infrared (not visible to eye i think). I've just snapped a quick pic of the opto encoder on my missile command - you see the two purple leds in the attached pic?
Essentially you have 2 leds that shine an infrared light to a sensor. As the plastic wheel turns it breaks/unbreaks the beam and that dictates movement. If you have any crap over the the led/sensor or the LEDs are bust then no movement. I'd try cleaning the optocoupler, check for LED's, swap the board from another wheel and validate working before going about purchasing a new board as that may not fix your issue if wiring/continuity problem.
20240606_173857-jpg.21285
hendrix77
5CR
Result turns out it was just a cotton bud thing gave them both a wipe and bingo both working thank you so much saved me so much hassle money and time 👌🙏
