Had a visit from Bonehead the other day as he was in the area. He mentioned he had a faulty Millipede and asked if I would take a look...
On first firing the board up it did nothing. Went over the CPU with the logic probe, no activity, so checked the crystal and found a pulse. Followed this through a transistor and onto a 74ls'04, still pulsing. However the output was dead. So I ran Slice up and grabbed the before and after replacing grabs...
Now the board was running but still had several issues...
The sprites were being drawn at the top or bottom of the screen in the wrong place and there were background colouring issues with varying brightness and blocks of background colour in the wrong place.
The sprite issue was useful as it guided me to look at the Motion Object section of the schematics, anyway after testing around 15 or so chips I found that the 256HD line was permanently high. This was used by around 4 chips and was being generated by a 74ls74 at 10D
This clearly showed pin 5 was failing at it should have been the inverse of pin 6. So I desoldered the chip, replaced it, and had the same result! So I started to follow the output to see where it went, 4 other chips, 3 x 74ls153's & a 74ls273. I went over these chips with Slice, most showed low activity but one of the 153's (7B) was generating errors.
I wasn't totally confident it would be the cause as the signal from the '74 was being fed to pin 1 & 15 which are the enable inputs. I really didn't expect this to be the cause of the line being pulled high.
However...
So I then retested the '74 at 10D and sure enough it was fine.
Repair complete, this bad '153 was also causing the background colour issues as well as the sprite problems. Only thing left to do is deflux the board and give it back to Bonehead.
However...
