Atari pokey chip remake
bonehead
I'll get pix tonight
50 (100%)
1,729CR
This may have been asked before but is it possible for these to be re produced in a more modern format?
With many failing everyday surely we will run out?
Now there are new Atari slapsticks available couple these pokey be remade?
Just a thought.
Steve
ColinD
6 (86%)
1,367CR
There is a lot going on in the Pokeys, I believe that some of it has been implemented to run on an FPGA but not the complete operation as its only partially done. Its missing at least the keyboard , serial and AtoD too although the design can probably spit audio out.
It might be possible to build something based on a micro controller like the swinsid for the c64 sid (which is more complex in many ways and simpler in others)
So... doesn't look like a solution will be available for a while at least !!
DanP
Administrator
2,232CR
I think at least a partial pokey replacement should be possible. I have a missile command bootleg with a "pokey eliminator' (a pokey implemented in TTL) so it must be possible to some extent. I'm not sure now much of the pokey MC uses. There's the sound generation part and the pots/keys bit and I think it's used as a random number generator in some games (lot going on as Col says). The IC's have had all there markings scratched off but somewhere I've got a list of what the ABI thought they were.
Mitchell Gant
888CR
I've got a partially done Quad POKEY eliminator prototyped up that I recently did some more work on.
https://www.youtube.com/watch?v=GIcezrwN6RE
https://www.youtube.com/watch?v=5WLjPLXP474
Bloody hell! 4 years ago that was!!
Originally it used a crude 12 bit DAC as a single output, but this time I used a slightly faster microcontroller and a proper stereo audio DAC bought from EBay. It struggles to do more than about 23kHz sample rate though. Sounds OK to me, but my hearing may not be perfect any more (he says listening to Motorhead while typing this).
It emulates a full Star Wars 6809/ROM/RAM/4x POKEYs but no speech synth.
I was toying with making it just into a Quad POKEY, though not many games use it, or some sort of dual POKEY to fit games like Space Duel, Gravitar, etc.
Doesn't have to do full POKEY feature emulation for those games. Reading an 8 bit input port for DIP switches, a 'random' number generator and the four audio channels is good enough for these games. No need for advanced analogue pot scanning, serial port or two tone features here.
Making that into a saleable replacement is the hard part though.
virtvic
The Cabaret King
21 (96%)
2,013CR
Even if just the sound was done - that'd please the Atari 7800 Mateos cart owners. You can install a pokey on it to get decent sound from the homebrew games.
Nes4life
1,134CR
That's pretty cool. I'm sure some of the guys here could miniaturise and improve on those efforts given the right mindset & incentives. Awesome stuff!
DanP
Administrator
2,232CR
Purity said:
That would be awesome if you can share the TTL version Dan
I'll try and dig the board out and go from there. I don't have anything else beyond the IC's list I identified using the ABI. Would love to spend some serious time on it, try and verify the IC's are what the ABI says they are, test the board in other games to see what is implemented, etc. Eventually would like to produce a schematic - yeah right one day....
