Atari Pole Position repairs
9CR
Hi,
I'm looking to find someone who can repair an Atari Pole Position board.
Mark Haysman no longer does them and have tried Craig Walker at Giz10p
but no luck.
Any suggestions anyone greatly appreciated.
Paul
DanP
Administrator
2,173CR
You may struggle. It's not just repairing the TTL that's the problem it's the large array of custom chips, weird CPU's (2 z8002's) and complicated architecture that this this entails. Surprised to hear Mark isn't doing them any more. Hope you find someone willing to take em on.
patloz
836CR
Hi,
but no luck.
Paul
Arcade Jason produced a plug in replacement PCB for the original Pole Position PCB called Pi Position, It runs a MAME version of Pole position and pole Position II which is the go to fix for a lot of people with PCB issues.
DanP
Administrator
2,173CR
Good shout, this is probably the best solution - I had one as a backup when I still had a PP2 cab for when the real PCB broke. With these it's only a matter of time so having a hot swap modern board to drop in while you're repairing the real PCB is a good idea. I still have mine somewhere - but not the cab, should sell it really - I had vague ideas of doing something else with it that never really happened.
9CR
I will check this out as I listen to a lot of Arcade Jason YT vids
9CR
Is it Pi position you stil have or the original PP2 board?
patloz
836CR
Any idea why Mark has stopped repairing them? he did a great job on mine about 12 months back it's a damn shame as he's excellent.
As Dan said its likely down to the failing of custom chips which he is struggling to get a reliable supplier, complicated dual layer PCB which is always carrying some battery acid damage and the likely hood it will go wrong again in a short timescale because they are the flakiest PCB known to man.
Mr20to5
1,344CR
Hi,
but no luck.
Paul
Just out of interest, what is actually wrong with it? Totally dead or booting to an error screen?
