Atari Pong (clone) repair
patzik
391CR
I have 2 boards in my pile that I want to take a look at. Took me a while to identify them but they are a chicago coin tv pong and a tennis coop 2.
The first one is a direct copy of pong, with one small change that a gate on c4 was omitted. The board looks ok after a bit of cleaning and there are some parts I need to replace before I can test it.
The second one is a bit of an odd board, and I can't find much info about it. What I understand it's pong too but with analogue sticks and you can move the bat left and right too. If you look at the board it's identical to pong, same ic's in the same place but there is a row of ic's above and below the 'pong part' of the board. This board has had a hard life, and many of the ic's are corroded.
My question at the moment is how to hook these up for testing. They work on simply 5v so I could hook this up directly to the filter cap, or feed between 9v and 12v dc to the ac lines. Both should work fine I think. I'm not sure about the video and sound though, pong feeds the video to vhf or uhf input of the tv, but I thing others have connected a pong board to composite, any suggestions on this? Regarding the sound, I assume I need an amp for this, am I correct?
patzik
391CR
patzik
391CR
Also looking on your opinion on the 2nd board. I don't think it's a well known game, and so not very much looked for. Seeing as how corroded some ic's are, is it worth saving or should I just use the parts that can still be used? I wonder how many ic's will survive if I take them out and clean them, I think many are so corroded that the legs will just fall off. i also cannot find a schematic for this board, for the pong part I can use the atari schematic, but the rest....?patzik2021-01-25 11:25:29
qjuk
51 (98%)
2,134CR
I wouldn’t be surprised if those Texas Instruments IC’s still work
If it was me, I would be gently removing the chips from the sockets and see if I could clean up the legs on them. I would certainly be giving the board a good clean though. Hopefully someone can find a pinout for the edge connector for you before you attempt to hook it up.
qjuk2021-01-25 12:24:24
patzik
391CR
Finding the pinout is not so difficult, the boards are very much like pong, and the first board had the same pinout. The only thing I am wondering is what the video out signal is. In the pong manual it connects to vhf/uhf, but when I look at the board it looks more like it is a composite signal. I want to connect it to composite so I think I will just try it and see what happens.
patzik
391CR
The #1 board had some blown diodes and was quite dirty, but still in good shape. So removed the pots and regulator and cleaned the board. Ordered some parts and caps and build it back together.
figured out the pinout and powered it on...
Nice!!
So it's working, but it does need some work. The picture is quite dim, don't know if and how I can improve this and the net is a bit to the left. I did find that this i quite common so I will look into this at a later time. First thing that needs to be fixed is the ball, it is completely missing. When I start a game I do see that it is playing because the bats appear and the score counts up. Haven't hooked up a speaker and pots yet so have to do that too. But so far so good....
patzik2021-02-03 14:08:48
patzik
391CR
It's hard to troubleshoot this, because I can't find any good schematics. I only found one that is hardly readable, and there is this pdf from pong story with a lot of good information but the parts of the schematics they use often don't have the pins mentioned. So if anyone knows of a good schematic please let me know.
Looking at the ball problem, I found no activity on vvid, tracing this back I found in the pdf from pong story how this is generated. There was no activity on pins 11 and 12 of B3 so I replaced this, and activity came back on these pins, however still no ball, A3 also had bad outputs so I replaced this one also and succes, the ball is now back.
So now I decided to look at how the paddles are hooked up and the speaker, and got this also working. Now the next problem came up, the sound. The wall hit and paddle hit sounds are fine, the miss sound however is not, it's on continuously so this will be the next step to troubleshoot, but I could really use a good schematic for this....
patzik2021-02-04 16:57:32
patzik
391CR
i noticed that during the attract mode the ball doesn't bounce off the left and right wall, it goes from left to right, off the screen and re-appears at the left side of the screen. Seems this is related to the sound circuit, as I found this in the pong story pdf.
The Score sound (SC) is able to clock H3, via D1, to allow the ball (HVID) to bounce off H blanking so the ball bounces silently around the screen attracting the next would be players.
patzik
391CR
G4 (a 555 timer) generates the SC signal and this is where something is wrong, either the 555 itself or more likely the input of pin2 /MISS. Will have to look into this further. Anyone here that has a pong board and can do some measurements for me?
patzik
391CR
So, after some more measuring and scoping the signals around that 555 timer, I was thinking maybe it is the 555 timer itself...
So replaced it, and all is fine now, the ball happily bounces from left to right in attract mode and the sound is also fixed.
So the board is 100% ok now
, love the simplicity of this game, and the history behind it...
Maybe in the future I will build a small cabinet for it, I saw a great idea while searching for info. I'm thinking a little different with maybe a small crt, but this thing looks awesome!
http://www.e-basteln.de/arcade/pong/pong/
patzik2021-02-04 22:10:20
Lurch666
21 (100%)
4,517CR
Dude!
Thanks for sharing this fix.
I'm hoping at some point to acquire and repair a pong (or clone) board so this sort of info in invaluable.
Nice one.
alanj
4CR
Hi i just got two nutting associates computer space balls in to help fix up for a friend. these are very early pong clones. museum pieces really as of course bushnell was at nutting then went and started atari etc.
anyhow. i only have one logic board so need another. if anyone has a working one. not sure if the one i have even works as both tv monitors are knackered. they are 15” tvs so quite hard to source a replacement. so will attempt to fix
