Atari Primal Rage PCB MOB Issues?
Djrouge
119CR
Wondered if someone fancied diagnosing/fixing this with me please?
I picked up a Primal Rage the other week, it was in good condition but I have issues with the PCB.
Here's the manual with schematics and parts illustrations etc..
http://www.rougenet.co.uk/arcade/support/primalrage/primalrage.pdf
When I booted up the game, I experienced extremely garbled screen, missing sprites and two thirds of the right hand of the screen missing (don't have a screenshot of that as I set straight to work hoping it would be edge connectors etc.
Here's a video of how it currently looks now:
MOB CHECKSUM TEST RESULTS:
I went on to inspect the board and check things.. Here's how it went:
[list type=decimal][*]checked 5v to the board and at the furthest point - all fine.[*]Went into test mode, all ROM/RAM tests passed, I did however get an issue shown above when testing MOB Checksum[*]removed the board for a close inspection and to clean up the edge connectors hoping for an easy fix.[*]put the board back in - no change[*]inspection of the board showed spillage and chorosion around the bottom corner (ROMS on rows V,W.) and when I press the rom down firmly, the glitches got better, almost perfect sprites so thought I would test this further.[*]Removed ROMS on rows V&W, the socket was choroded and continuity from the socket where the ROM legs/pins insert and the solder side showed a couple of broken circuits on socket W.[*]Rightly or wrongly, I decided to remove the socket and solder the ROM direct to board and tested all pins to the next point in the track - all tested fine for continuity.[*]Now the sprites are visable and image displayed full screen but still have some garbled sprites going on. looks about 50% better than it did but still not right.[*]I removed all ROMS at points 1S, 11S-15S,17P, 22U to clean the legs and used contact cleaner in all of the sockets - this has made no difference. (9T is like a square CPU chip, haven't removed this yet as it looks a bit fiddly)[*]I went on to further inspect the board, re flow any suspicious looking solder points and still the same garbled sprites[*]I plan to go on and test more components and traces around the suspicious area where the spillage occured but I don't have a logic probe.[/list type=decimal]
The other thing which made me think was the fact that on two roms (25,26N I think which are playfield roms) had their stickers missing and window exposed. Could this corrupt the ROM?
Playfield scrolling in test looks like this:
And the suspicious area of the PCB looks like this:
I completely understand if you have enough on your plate to start delving into this with me but if something looks obvious, please let me know.
I don't have a ROM burner so can't re burn the ROMS with the windows exposed, I've covered the windows now though, not that that would make a great deal of difference if it is corrupted and needs re burning.
Hope you can help and I'll update this thread with my progress if I make any.
Kind Regards,
Tony.
tb2000
3,579CR
If you don't get anywhere with this I have about 3 or 4 primal rage pcbs and at least 2 work 100% if you decide you want a replacement.
You can get a corrupt ROM if the quartz window has been exposed to a lot of sunlight but I doubt you'd get any problems with that in the back of a cab where it's normally dark.tb20002017-01-14 19:31:55
