Atari Star Wars small gear replacement
yorkshire_spam
765CR
The plastic outer has snapped off the small spur gear in my Star Wars yoke controller.
It's "proper" size is 14T 24 DP (or 24P) which is an Imperial size, expensive and hard to source this side of the Atlantic.
I bought a cheap-n-nasty Mod1 14T (metric size) that's the closest metric equivalent and fitted it - it seems to work fine so far
https://www.ebay.co.uk/itm/174115912065?var=472993239306
14T, 6.35mm bore fit fine with no modification.
Time will tell if it holds up, continues to be nice and smooth and doesn't eat the plastic off the larger gear in the controller. For now I'm happy with it for the bargain basement price compared to the "real thing"
It's all @ColinD 's fault: http://www.ukvac.com/forum/atari-yoke-star-wars-14-tooth-gear_topic371787.html
yorkshire_spam2021-04-27 18:06:02
ColinD
6 (86%)
1,367CR
I've had stuff from HPC gears.
Here is the 24DP stock spur gears..... https://www.hpcgears.com/pdf_c33/23.102-23.107.pdf
They charge a very reasonable small fee to modify stock parts if you need to tweak them.ColinD2021-04-27 13:29:18
yorkshire_spam
765CR
14T, 6.25mm bore fit fine with no modification.
Cheers for Sharing.
Had a quick look at the link - did you mean 6.35mm (instead of 6.25mm). Just checking before I order one.
Yes, sorry, 6.35mm (original post updated to correct the error!)
