BAS Cabinet height
Retrojedi74
86CR
Hi All, could someone tell us the height of a standard BAS cabinet as I’m trying to fit one into hire van maxi that has a depth of 1.70 Metres once I have laid down the cabinet into the van. Don’t worry I’m changing the cab monitor over once it’s back at my house. Thanks in advance guys
_Matt_
965CR
The problem is there are probably a couple of BAS cabs that could be described as standard. I think the smallest standard generic jamma cab that BAS sometimes used is around 66" give or take ½" which may just fit. Have you actually measured the van as sometimes bulkhead lean back into the van the measurement at the bottom maybe bigger than than at the top. Have you got a pic of the cab?
big10p
Coins detected in pocket!
6,093CR
I've collected a couple of JAMMA cabs (not BAS) in my mates small van before that didn't quite fit, but we just tied the back doors together.
Kev A
747CR
Mines 166cm, I have replaced the bottom section on mine as it was rotten, but was quite careful to get it similar to what was there before.
that's the style mine is....
Kev A2021-07-22 10:08:27
antray84
571CR
What's going on with that bezel? Someone has done some rather poor resto work with that. They are great machines, but check it out first as that seems a dodgy fix. It is clearly not centered.
