Battlezone
Body pop
24 (100%)
1,266CR
I picked this battlezone up this week .
When switched on ,I’m getting 4 low beeps followed by a high beep and then 1 low beep
All leds are coming on on the boards ,led on monitor is on too with neck glow
Nothing on screen .is this a ram error ?
Anyone any experience with these please
Body pop
24 (100%)
1,266CR
Cheers alpha ,just had a look there and I assume the high tone is the the problem ram ?
On the manual it says it’s b2 then ?
Is anyone repairing them on here ?
aeroflott
A different league
16 (100%)
1,061CR
RGP is your man for all things BZ tech, but based on my cack-handed experience, the sequence you describe sounds like a bad ram at B2 according to my manual. But the tones should stop at the first bad ram the game finds in the sequence, so I'm not sure why you're getting another low beep after the high beep.
Do you get anything displayed on screen? What happens when you switch it out of test mode?
Body pop
24 (100%)
1,266CR
That’s a good question ,is the test mode a dip switch then
Il try that and see ,it was working up at the auction ,but the tech guy had mentioned about a bad ram so he must of put it in test mode .they were quite rough with them so I will try a bit of reseating connectors ,just incase
Nothing on the screen
Body pop
24 (100%)
1,266CR
With test switch off I’m still getting nothing .
It’s all really clean in there ,looks like the ar has been done recently
So it looks like it’s b2 on the top board then?
Il stick some pics up
Mitchell Gant
888CR
RAM chip B2 that test mode reports as faulty is on the larger PCB (lower one on your photos).
On my PCB chip B2 is just under the "USA" of the text the says "Made in USA" which is etched into the copper of the circuit board.
RAM failure on Battlezone is a favourite failure for them. The built in game RAM test is not perfect and it's not a 100% guarantee that it's simply B2 at fault.
From your photo I can just about make out that RAM chip at B1 may have had a socket fitted at some time in the past, but the cable harness is blocking the view of chip B2.
If you're lucky that has a socket too and you can just swap in a replacement RAM chip. If not you'll have to cut out or desolder chip B2 and replace it (with 2114 or 2148 RAM). Best put a socket in for when you inevitably have to swap out in the future...
5,653CR
Does the Battlezone high score save kit elimate the rams and roms? Might be worth just buying one of those hehe
Body pop
24 (100%)
1,266CR
I don’t nad .wheres best to get them .
I’ve heard that phrase before ,does it mean you just cut the top bit off and join a new one ,or how do you go about it
